rjbranchii
MI, USA Status: offline
outacontrl I was a member of RCCD the last two years but just for control line flying. I fly RC with the Flyin Wolverines Club in Algonac, MI which is the mainland across from Harsens Island. I don't fly RC at RCCD. They only fly cirucular patterns. To fly true aerobatics I had to be so far away I could not hear my motor on a .40 size plane. Much less see anything for 3D. The Wolverine club is much smaller, about 35 members, totally noncompetative, and our field is actually bigger... like 2800 ft! Its a former private grass strip. We opened up about 850 ft of it to 250 ft wide, and mow 1200 ft of the original runway to carpet length. But if you need it for an engine out, there is the full 2800 ft that is cut usually to about 4 to 6 inches beyond what we cut. With that small a membership we can fly close in aerobatics of any kind we want. Additionally we have a tree line behind the east west flight line that has a row of trees about 75 to 100 ft high that blocks the strong southerly winds. So we can litterally have a calm runway when the winds are 25 to 30 knots out of the SW, which is our strong wind direction here. Its taken us 3 years to develope the site. We hope to get final finishing of the road with crushed stone in the next few weeks and it will be about as ideal as you could want. Right now we have a damp road issue that prevents access in the spring til it dries. As to batteries, I have flown only 6 volt systems for about 4 years now. Bigger servos take alot of juice. I fly my .72 to .90 size 3D planes on 1400 mah nimh batteries. But I have found the need to recharge after 4 or 5 flights on that size servos (120 oz rudder being the largest). The large digital servos I'm going to use on the giles have me planning on about 22 to 2400 mah nimh. I am running 4 stroke glo so I don't need an ignition battery. I know some have used smaller. But I don't think I've heard anyone going under 1400 mah. bob
