smarkfagan
PA, USA Status: offline
My first post in this forum. Have been reading it for awhile. I'm building one too, here's what I've picked: OS 120AX Bisson Pitts Hitec 635 Rudder Hitec 475 Elevators (dual, in tail) Hitec 475 Ailerons Hitec Standard Throttle 14 oz tank Fiberglass Specialties cowl May not seem like much servo power to some but this is my 3rd year at the hobby and won't be doing anything crazy in the sky. After the trainer I built a 4*60 and now this. My kit too suffers from poorly fit parts, had to do alot of trimming to get things to fit right. Sofar the wing is done, tail surfaces, and the fuse up to where I'm ready to put on the tail. Should be covering soon. Anybody else think the servo tray is really flimsy - from what I can tell it only attaches at the front and rear, so the whole tray is like a trampoline. Also, the tank tray - I take it you don't glue the tray in place, just rubberband the tank to it and wedge it in with foam? One last question - not sure what to do about fitting the cowl over the pipes without cutting away the entire bottom of the cowl. Thought about installing the muffler after the cowl (with small access hole for allen wrench) or cutting pipes short enough. I welcome any thoughts regarding my setup or questions. Thanks in advance, Steve
