swixtt
quote:
ORIGINAL: Not24 The only thing you should concern yourself with is symmetry. The radius of a corner will never be considered unless it is different from the other side. Take the time to add the bow to the rudder. It is a trademark of the airplane, and really shouldn't be omitted. The wing ribs in mine, the plywood ones, were too long, causing a bow in the leading edges of the wing. This is where you should be sure to have the parts fit well before gluing anything together. Well, things are moving along... a little slowly though. Didn't get much time to work on it over the weekend. busy fixing my basement common area! so far i've got one side of the stab done. everything is matching up for the heights, etc. and i'm just using the die-cut sizes making sure i keep things straight as possible. i'll be sure to put the bow in the rudder too. didn't see that until you mentioned it and looked at the drawing!
