Not24
VA, USA Status: offline
quote:
ORIGINAL: ctei Well I am just about finished with my Sukhoi. I am not impressed with this Goldberg kit, some parts did not fit well and most die cut plywood parts were not cut all the way through. I (?) made a serious blunder in building the wing, when I finished the wing would not fit over the fuselage. I have been biulding for over 30 years and never had this problem. I built the wing over the plans but the space between the two #2 ribs was not wide enough. Goldberg provided spacers to make sure the ribs were spaced correctly but not between the #2 ribs which is the most critical dimension on the whole airplane. I was not able to salvage the wing so I ordered a wing kit which came with 4-5 parts missing. I called Goldberg and they quickly sent replacements, however they still missed some parts and sent extra wing tip blocks, go figure! So much for the bad news. The finished product is looking good. I opted to use the ABS cowl and the kit supplied landing gear but may replace these later. I plan on using a Saito 120 with a Pitts type muffler. This is the first plane I covered with Ultracote and it is great covering material. Currently installing the radio, then check CG (I moved as much stuff up front as I could, see e.g. battery location in attached photo) and she should be ready to fly. Will attach photos if I can figure out how. I had a problem with the wing also. It seems the plywood ribs are not cut right, and they push the main spar and the leading edge forward out of position. I didn't notice it till it was impossible to fix, so I had to live with it. It required cutting the TE a little to fit into the fuselage. Other than that, it has gone together nicely. I would have seen this problem had I assembed all the ribs on the spars in two stacks. I would then have seen the mismatch in the lengths and could have fixed it then. The abs parts are very sturdy, but the material tears very easy, so proper reinforcement is a must. Any ideas on torque requirements for the servos? That's next on my list.
_____________________________
Fly it till you break it!
