*Turning An Engine Horizontal*
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> *Turning An Engine Horizontal*
Page: [1]
Login
*Turning An Engine Horizontal* - 6/18/2005 7:40:38 PM
Zippi
Status: offline
I have just got the new Model Tech "Formula 3D" and the engine mounts inverted and the mount is in the wrong place. I want to mount the engine horizontal. What is the best way to figure out just where to place the mount on the firewall to ensure that the prop shaft is in the right place to fit through the cowling and line up right?
_____________________________
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 1
RE: *Turning An Engine Horizontal* - 6/18/2005 8:09:37 PM
voyager_663rd
Status: offline
Maybe in your instruction book there is a template that you cut out and put on the FW ? Failing that, use the pre-drilled (hopefully) hole in the FW where the fuel lines poke through and put that hole in the centre of your mount.
There should be a X-template though.
Len-> More questions than answers some answers are here [url]http://www.freewebs.com/rc_tips_and_hints[/url] 18,000+ hi
(in reply to Zippi)
       Post #: 2
RE: *Turning An Engine Horizontal* - 6/18/2005 8:22:23 PM
Zippi
Status: offline
No templates, the engine was meant to be mounted inverted. I want to mount it horizontal but I want to make sure that the prop shaft comes out in the center of the opening on the cowling.
(in reply to voyager_663rd)
       Post #: 3
RE: *Turning An Engine Horizontal* - 6/18/2005 9:18:11 PM
voyager_663rd
Status: offline
holes pre-drilled in the mount for the inverted position?
(in reply to Zippi)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.312RCU2
