RE: Cold Duck - Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Cold Duck - Build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Cold Duck - Build - 7/13/2005 5:49:14 PM
8178
Status: offline
quote:
ORIGINAL: woops
Why don't you fly your Tiporare before you finish this plane.
I had to send in my “rocket ship waver” application to the AMA so the Tiporare can be flown. Expect to receive the waver any day now, then we should be all systems go.
_____________________________
Builder and flyer of high performance acrobatic R/C aircraft and a proud member of VR/CS.
Made in China = no sale!
(in reply to 50%plane)
       Post #: 26
RE: Cold Duck - Build - 7/13/2005 6:31:33 PM
50%plane
Status: offline
I've never heard of that.
How fast does it go?
Should I have gotten a waver last time I flew my Laser Arrow at 200+mph?
Model Airplanes don't kill people. Chuck Norris kills people.
Christopher A. Todd AMA# 637636
(in reply to 8178)
       Post #: 27
RE: Cold Duck - Build - 7/14/2005 6:52:36 PM
8178
Status: offline
View of the fuselage with the sides glued to the top. I shaped the triangle corners on the tail section by test fitting the sides to the top and then glued the two sides together at the tail first. After the glue on the tail was set I took it apart and put epoxy on the firewall sides and the second former and Titebond on the third former. Titebond was put on the top edges and triangles on the fuselage sides and the sides reassembled on the top and taped. I placed the fuselage on the workbench upside down and put weights on it to hold it together. The scribed line on the underside of the top was used to make sure the tail point of the fuselage was centered.
View of the progress with the fuselage parts sitting on the wing cores. The nose blocks and nose ring are not installed yet. A lot of razor plane work will be done to make the top of the fuselage very rounded and flow into the rounded nose section and 2” spinner.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 8178)
       Post #: 28
RE: Cold Duck - Build - 7/14/2005 7:03:26 PM
50%plane
Status: offline
It doesn't look like this plane is going to take 14 years to build.
(in reply to 8178)
       Post #: 29
RE: Cold Duck - Build - 7/14/2005 11:10:44 PM
Jim_Purcha
Status: offline
Very nice craftsmanship on the plane. Parts almost look laser cut. How does your wife let you get away with always photographing your models at the top stairs?
(in reply to 8178)
       Post #: 30
RE: Cold Duck - Build - 7/15/2005 12:07:26 AM
8178
Status: offline
quote:
ORIGINAL: jpurcha
Thanks for the positive input and I’m having a lot of fun with this build.
My RC workshop is in a very large unfinished walk in closet/bathroom (supplied with HVAC) that is located next to our second floor loft area, so my shop is too small for photos. The photo is on the entrance to the bridge that ties the loft to the other side of the second floor and stairs (very southern). If everything is clean then it’s OK to drag it out to the loft to take photos and get a feel for how the overall progress looks.
(in reply to Jim_Purcha)
       Post #: 31
RE: Cold Duck - Build - 7/15/2005 11:12:43 PM
8178
Status: offline
View with the nose blocks and nose ring installed and some of the fuselage shaping completed. The lower ¼” balsa part of the back fuselage is just taped on and I’ll glue it on after I work out the push rod routing. The fuselage weight at this point is about 9.5oz. Super light!! I need to resin the engine and fuel tank area for fuel protection so that will add a little weight. It would be pretty neat if this baby came in round 5.5lbs. You can never be too light or too fast!!! The original was pretty fast with the old Veco 61 at 6lbs, imagine 5.5lbs with a hot 61.
The wing is missing the 1 ½ wide aileron stock so it looks a little skinny in the photos. The symmetrical airfoil on the Cold Duck is an 18% - 15% taper. No need to create a lot of drag with a fat airfoil.
The Webra 61 has been temporally installed as a jig to setup the nose ring position. Getting the 1/16 ply wood nose ring positioned correctly was a pain but eventually I got it right on the mark.
I’m not happy with the looks of the Great Planes canopy. It is too short and narrow, so I’m going to investigate the Wing canopy recommended by Paternguy .
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 8178)
       Post #: 32
RE: Cold Duck - Build - 7/16/2005 12:38:33 AM
8178
Status: offline
View with the ailerons taped on.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 8178)
       Post #: 33
RE: Cold Duck - Build - 7/16/2005 12:07:46 PM
50%plane
Status: offline
Lookin good.
(in reply to 8178)
       Post #: 34
RE: Cold Duck - Build - 7/17/2005 3:29:22 AM
Paternguy
Status: offline
You could always go with the Wing MFg ck 604 (Dirty Birdy) Canopy. LOL
Might look pretty sharp on this bird.
(in reply to 8178)
       Post #: 35
RE: Cold Duck - Build - 7/17/2005 3:29:11 PM
8178
Status: offline
The engine opening has been ruff cut and will be cut to the exact shape latter. The small area behind the nose ring is too complex to fill completely with balsa so I filled the area with a small amount of mirco-balloons mixed with epoxy. You can see the cuts in the triangle corners pieces to allow them to easily bend to the shape of the nose.
The inside of the nose area and fuel tank area was fuel proofed with epoxy thinned with alcohol. The bottom piece below the tank was fuel proofed before gluing it to the fuselage. I added a few triangles behind the firewall to strengthen the mounting.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 8178)
       Post #: 36
RE: Cold Duck - Build - 7/18/2005 4:16:52 PM
smallcirrus
Status: offline
I think its very cool that somebody else is a fan of the Cold Duck my father scaled that plan to take a 40 fsr in the early seventies and then in the early eighties he rescaled the plans to suit 25 size engines. I have the original prototype of it that my father built as a construction and plan article for the magazine he published, what father did was to simplify some areas of the model yet keep all the basic charm of the original scaled down to a 25 size sports model, the one I have is powered by a 25 year old OS 25 fsr and it is still a great fun aicraft to chuck around even today.The so called Mini Duck keeps nagging at me to biuld an even smaller one for electric power,perahps one day I'll get around to that as a project.
regards
Alexis
(in reply to 8178)
       Post #: 37
RE: Cold Duck - Build - 7/18/2005 5:00:46 PM
8178
Status: offline
quote:
ORIGINAL: smallcirrus
regards
Alexis
Alexis,
I’m a big fan too but I have a little biased connection with the Cold Duck. Interesting about your father rescaling it to a smaller size and I’ve met other people that have built it from the RCM plans as well. Apparently the original RCM article made it all the way down to Australia! It would be great if you could post a photo of his article and your current Mini Duck on this thread.
Some images of the original June 1971 RCM article are below.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by 8178 -- 7/18/2005 5:16:24 PM >
(in reply to smallcirrus)
       Post #: 38
RE: Cold Duck - Build - 7/18/2005 5:06:42 PM
8178
Status: offline
The lower front of the fuselage has been glued on and shaped. Epoxy was used at the bottom of the firewall and along the bottom of the second former.
More work was accomplished with the razor plane and the characteristic curvy flowing lines of the Cold Duck are starting to show. It’s pretty cool to see it comi
