jeffo
Joined: 12/8/2003 From: new baltimore, MI, USA Status: offline
Rainday- Usually you run a nyrod tube down the length of the fuse while you are constructing the fuse.You may have to flush off the end of the tube with the side of fuse when exiting.Cover fuse to suit,then cut the coveringout of the inside of the tube.So the antenna wire can pass thru.The only problem you have to watch for is if you have your servos in the tail, the servo extension wires can cause interference.I had a Miss Los Angeles with servos in the tail,I ran the antenna wire down the side of the fuse and the servos glitched constantly.I moved the antenna wire out side the fuse problem solved- -Jeffo
