RCtruckRacer
Joined: 6/2/2005 From: Eugene, OR, USA Status: offline
In the future, I would agree with dOWa and go for another mach... but with all the current problems I have been seeing, you might want to steer clear of them for the moment. If money were no object, I would say go with the Sirio .27 racing engine (3.1hp), as from what I understand, everything, including the stock clutch will bolt right on. Otherwise, you should probably consider the Collari .30. There are some slight modifications that need to be made to get it to fit, but lots of LST owners are using it, and it's relatively inexpensive - I think around $200. Whereas the Sirio is over 3 bills. If you go with another mach, make sure that you put it in the truck right away, and break it in asap so that if it is a bad one, you can get a replacement (3 month warranty I think).
_____________________________
Some people see the glass half full. Others see it half empty. I see a glass that's twice as big as it needs to be. My opinions are my own, and are not necessarily those of RCU
