opjose
MD, USA Status: offline
quote:
ORIGINAL: f_shawn68 I usually fly it at 1/2 throttle and it moves along pretty well but still slows well on approach. Several guys at our field have learned on this plane and informed me that the speed brakes make it hard to trim the plane as they cause alot of turbulance. I also installed the flap servo, but have never used it. It comes in slow and smooth without the need of flaps. I only needed to use 1 oz to balance mine with this setup. The speed brakes are designed to be used in conjunction with the flaps deployed. The flaps tend to cause the plane to nose up, while the breaks pull down a bit, so the two balance out. Couple this with the low speed prop and extensions, and a newbie can jam the throttle without the play screaming away beyond their control. If used as it was designed the combination of all of these things work well. The problems arise when someone ( and at times instructors ) take the plane up, find that it's seemingly too slow, and start advising that the aids be removed prematurely. In turn this results in some of the comments about the PTS being unsuitable as a trainer. The stock prop is meant to be used on a smooth runway.
_____________________________
- Build em'', fly em'', crash em'' and build more.
