RE: New Hanger 9 p-51 mustang **Trainer?!?**
Tower Hobbies
Logged in as Guest
Users viewing this topic: Attila
  Printable Version
More Resources on the
P-51 Mustang PTS
  • 2 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: New Hanger 9 p-51 mustang **Trainer?!?**
    Page: <<   < prev  194 195 [196] 197 198 199 200 201 202 203   next >   >>
    Login
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/17/2008 2:58:48 PM
    RedTwilight
    Status: online
    quote:
    ORIGINAL: smooreace
    quote:
    ORIGINAL: Wild_CCR
    PS- I put a ribbon back on the end of my antenna, so I can see what the wind is doing
    Ribbon on the antenna? Isnt that for those "Frequency Concerned" fliers out there? I have always flown 2.4 gig, so that ribbon and freq card seem to be more of a hassle and annoyence to me. Especially here in Kansas where the wind is ALWAYS blowing so bad that all you hear is ribbons snapping in the air.
    The ribbon on the end of the antenna act as like a mini wind direction indicator. That way you don't have to take your eyes off the plane to turn around and look at the windsock. But with the stubby antennae of the 2.4 systems it may not work as well.
    _____________________________
    Parkzone P-51, Hangar 9 P-51 PTS
    '96 Mustang Cobra 330hp
    (in reply to smooreace)
           Post #: 4876
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/17/2008 4:33:26 PM
    smooreace
    Status: offline
    Purhaps I could attatch a piece of ribbon to the tail of my plane Then I can tell what direction its going! It could reallt be confusing if your late in your approach and find that you actually came in backwards! That would REALLY screw with the aerodynamics of the plane. In fact, that would almost make the droops act as flaps. Scary scary SCARY thoughts!!!
    For those not so speedy in the thinker.... yes, Im kidding
    Im going to head out agian tomarrow and see how much fuel I can burn. I never thought about how fast a gallow can go away when you flying, or trying to fly, multiple birds. I wish I caould fly and take pictures myself, but like looking at the windsock, thats a little too dangerous.
    Today: Mostly sunny, with a high near 82. Northwest wind around 10 mph.
    Sunday: Mostly sunny, with a high near 82. Northwest wind 5 to 10 mph becoming southwest.
    Monday: Mostly sunny, with a high near 85. South wind 5 to 10 mph becoming northwest.
    With 3 days of perfection, and nothing to do but fly..... Im going to have to take a case of fuel to get me thru the weekend. WOOHOO!!
    (in reply to RedTwilight)
           Post #: 4877
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/17/2008 5:03:40 PM
    beatlebum
    Status: offline
    Nothing yet. They got it thursday, so im going to call them maybe monday or tuesday and see if they have had a chance to look at it. I got a bonus from work so im really thinking about getting the nexstar if horizon replaces my fly away mustang. If they dont im going to have to buy a arf and fix it.
           Post #: 4878
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/17/2008 7:05:59 PM
    The_Russian
    Status: offline
    Using the DX6i will require you to make a change to the wiring setup for the battery/on-off switch. The stock one will not work or bind with the AR6200 system. Try to find an MPI switch with exterior charge plug that is made for JR radios. You will need to modify the hole where it will mount by making the stock hole bigger. Make sure you have a female bind plug. That way you can bind from the outside without removing the wing and charge the battery from the outside too.
    Let me know if I can help you out. I can give you the part number if you need it.
    (in reply to thelocksmith)
           Post #: 4879
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/17/2008 7:24:29 PM
    smooreace
    Status: offline
    Here are 2 options to solve the issues previously mentioned. The Russian was talking about a part similar to the first image. I like the second solution better. Its a little bigger, and heavier. But for the PTS its hardly going to effect it anything. The all-in-oneness makes the radio compartment a lot cleaner, lots less wires.
    BTW.. the first image isnt of a PTS
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    (in reply to The_Russian)
           Post #: 4880
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/17/2008 11:17:43 PM
    The_Russian
    Status: offline
    The second one was exactly what I was talking about. I have the same one and it works great.
           Post #: 4881
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/18/2008 3:14:30 AM
    KentuckyColonel
    Status: offline
    I have both systems. The one in the first photo is similar to what I have on my PTS P-51, the second is the one I now prefer, and use for my other planes. They both work just fine, but #2 is a lot cleaner looking.
           Post #: 4882
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/18/2008 4:13:21 AM
    smooreace
    Status: offline
    Picture one is wat I have on my PTS Mustang, but the power and charge ports are on opposite sides. This is what I have on my .60 Mustang, and same configuration on my giant scale planes. Im going to switch to the combined switch/charge on all planes next winter.
    Click for fullsize
    (in reply to KentuckyColonel)
           Post #: 4883
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/18/2008 10:31:18 PM
    wldhair
    Status: offline
    Beautiful day here and nobody around to fly GRRRRRRRRRRRRRRRRRRRRR My instructor is a farmer and its a busy time of year for him and I understand that.I have a few days off work next week and I hope we can get together sometime during that period and get the P-51 up in the air .
    I guess I'll wait a little bit and go fly my park flyer supercub , I haven't had that inthe air yet this year and I know its not a P-51 at least its better than sittin here watching the dandilions grow .
    We don't get days like this too often during the spring , seems a shame to waste it .
           Post #: 4884
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/19/2008 2:04:56 AM
    wldhair
    Status: offline
    Well , I went out to fly my little hobby zone supercub tonite . It was a nice evening b ut really a little to windy for my poor little foamy supercub It took off just fine but once it was up inthe air a little ways (say 50 ft) it really had a hard time battling the wind . Up wind it hung there like a seagull and down wind it took off like a jet LOL The last flight I allmost lost here when I turn and went downwind . A big gust came up and before you know it she was ALMOST out of range . I was just lucky that the wind died off a little and I was able to turn her around and get her headed back towards me . She was headed for a cow pasture with alot of swampy area by a small river. I didn't want to go after her . BUT I took it as a omen . I landed her and decided to call it a nite . I guess you could say I WON LOL.
    Not much else happening ..MAN the weekends go fast
    (in reply to wldhair)
           Post #: 4885
    RE: New Hanger 9 p-51 mustang **Trainer?!?** - 5/19/2008 2:54:34 AM
    smooreace
    Status: offline
    Almost perfect day here today. I took 3 planes to the field and only had damage to one. The the first plane, added in-flight to the PTS equals the 2nd image.
    Long story short... I dont know where the P38 came from, but I flew thru the fusalage and too about 1/3 of its wing. It was spread out over maybe 75 feet. I recovered my plane and made a small pattern but noticed a bad pull to the right, so it hobbled in with the pictured wind damage. It actually flew amazingly well considering the impact. I was pretty much wide open on a downwind to left base when it happened. Just one more bit of proof that this thing is build strong. Yest, the P38 is a foam plane, but the fusalage is about 6 in diameter...... it sounded like I his a brick wall.
    Click for fullsize
    Click for fullsize
