Wild_CCR
Joined: 1/8/2007 From: LadnerBC, CANADA Status: offline
quote:
ORIGINAL: wldhair Thank you Ozmacka I don't think I would have known to look for that . God Knows I've checked and re checked everything on this plane I can think of . I have 2 of these planes and I'm being kept pretty busy doing all the mods that are coming up on this thread. I reinforced the fuse last nite but I have NOT taken the muffler apart yet BECAUSE when I try to take it apart , I feel like I'm gonna break the screw . It so tight that it really feels like its gonna snap if I keep trying to turn it . Maybe I'll wait on this and see if it comes loose on its own , everybody says it will , so I'll wait and see . Thanks again for the explanation Tom * Make sure you remove the nut on the back end 1st! The 4" (approx.) bolt, screws into the back portion of the muffler(inside), then the nut is used as extra security. To re-assemble, put the muffler together, insert the bolt & tighten, then add the nut at the back and tighten it. Carefull with the oring, don't pinch it when putting back together. Don't loose the tiny little split washers, one at each end. A drop of "blue" Loc-Tite always helps too. If you take the nut off, you'll see that the muffler stays together. Then unscrew the bolt from the front. Hope that makes sense?
< Message edited by Wild_CCR -- 5/21/2008 12:07:06 AM >
_____________________________
"Hey Honey! Look what I bought"
