Wild_CCR
Joined: 1/8/2007 From: LadnerBC, CANADA Status: offline
"Very first thing I did was glue my fingers together with CA, man I hate cutting the tip off a new bottle. " I usually end up w/ half of whatever I'm working on, stuck to various parts of my body. wldhair- check the line inside the tank too, it gets overlooked. Still the 30mph+ winds around here, rain on the way again..grrrrrrr STILL some snow on the mountians, end of May, very unusual. glasair72- that may be a little too much prop (11x6x3) for the stock engine, most likely only turn in the 9000rpm range and suck a lot of fuel. 11x6x2 APC ( 11,500rpm-ground ) seems to be the best all around. But give it a try! Just take care on take off, make sure you have the speed up and nice steady shallow pull out to make sure she doesn't bog down on you. I like a Graupner 10x6x3 also. (10,600rpm on the ground) Not quite as peppy as the 11x6x2, top end almost as fast, takes longer to get there, but a little quieter, cuts fuel use in half. Downside: the climb is not as good. The 11x6x2 will climb forever at about 60 degree, the 10x6x3 will not, but it acts a little more scale like. What I've found: 11x6x2 = about 12 min at mostly full throttle 11x7x2= about 10 min at mostly full throttle 10x6x3= about 18 min at mostly full throttle *stk engine-no baffle & flywheel removed. I usually bring both the 2 and 3 blades(&spinners) w/ me. Some days are just need for speed & cloud punching. go away rain......
_____________________________
"Hey Honey! Look what I bought"
