Wild_CCR
Joined: 1/8/2007 From: LadnerBC, CANADA Status: offline
yup, lil toooooo lean. to lateral balance, grab an assortment of samll finishing nails ( very small head ) say 1" to 3" or so. Pull out the plug so the engine compression doesn't get in the way, hold it from the very tip of spinner, and very back of fus, right in front of the rudder. probably take two people. You have to hold it lightly, one finger tip if you can, so that you allow it to move easily. Gently pick it up a few times, if one wing is heavier, it will tend to roll that way, even just so slightly. Try the different nails by laying them on the very end of the wing tip. Keep lifting and seeing what the results are. When you have the right balance, tap the nail(s) into the outside edge, more towards the front, so that nail is facing the fuselage. Shouldn't take much. Mine needed 2x3" finishing nails. The further you can put any weight, front, rear or wing tips, away from the cg, the less wgt you'll need. You can use a drop of ca to hold in place, a strip of covering if you have, or some clear tape. There is scuff tape that will work great & save the tips for those occasional tip hits also. Glad it went well, happy flying! ps- knees knock a little, its ok...we all have at some point
_____________________________
"Hey Honey! Look what I bought"
