mydartswinger
NC, USA Status: offline
According to the 2008 AMA Member Manual (found here), on page 3 (National Model Aircraft Safety Code), under Radio Conrol, bullet #9: Radio-controlled night flying is limited to low-performance model aircraft (less than 100 mph). The model aircraft must be equipped with a lighting system which clearly defines the aircraft's attitude and direction at all times. Unless there are more rules that are buried somewhere, I know of nothing that limits the design of the aircraft to high wing. Also, reference Fly RC magazine's June 2008 issue on page 52. There is an article on hooking up LEDs for night flying. The airplane being used for the project is a Multiplex Acromaster kit, which is clearly not a trainer type airplane, but a low/mid wing "pattern" shaped airplane. If the safety code is the only set of rules for flying (according to AMA), then as long as the plane flies less than 100mph regardless of design, you should be good by AMA rules. Your club may have implemented an additional restriction. If that was the case, the person that brought it to your attention should have said it was a club rule, not an AMA rule. Maybe someone reading this can point you where to look for more detailed rules. Hope this helps
_____________________________
Stop Playing Lawn Darts!!! AMA# 909181 www.davisbridgeaeromodelers.com
