jim pettis
NY, USA Status: offline
Well, been away for a while, both here and the field. Finally found time to get back into it. Finally found out just what a tip stall looks like, unfortunately. Came in a bit too slow, tried to flare the landing a bit too much, and from about 3-4 feet up, plane just turned 90 degrees in a microsecond, and put the wing tip and nose into the ground. I heard the crunch from 75 feet away. Luckily, no damage to the wing itself. Messed up the saddle area on the fuse, as well as the mounting block for the wing screws, but its repairable. Just another reminder that this plane does like to come in with a little bit of oomph.
_____________________________
Work is for people who don't know how to fly....
