olstoney -> RE: New Hanger 9 p-51 mustang **Trainer?!?** (9/12/2005 9:25:04 PM)
Mike, Yep, except they use that aluminum clamp type mount jeez I hate those[:@]. I took measurements off opposite sides of the firewall to make sure that the prop drive was lined up at the correct distance from the firewall. The hardest part was getting the cowl off. Now it slides on nice and easy as the OS cylinder and head is smaller. I am very pleased with the install, just gotta see how it flies without the cowl at first and will probably make some thrust adjustments. I bought a 2 1/4 Dubro spinner 11 X 6 and 11 X 7 props today to start out with. I tach my engines, so after this puppy is broken in I'll prop from there off the tach readings. tychoc, Are you referring to this trainer version of the Evo, or the other model that sells for more money? I'm not going to start an engine war, but have never had an OS let me down and I find them quite reliable, user friendly and easier to adjust. The FX feels lighter than the Evo as well. You like the Evo, so enjoy it, I'll make you an awesome deal on this new one complete with the muffler, spinner and prop if you would like another[:D].
