Jim_McIntyre
ON, CANADA Status: offline
quote:
ORIGINAL: britbrat If it is so, is it confined to the burgeoning ARF world? Not confined to, although I have witnessed many ARF failures due to poor contruction quote:
ORIGINAL: britbrat Perhaps it is a constant rate, but with numbers increasing due to greater involvement. That could very well be. I think Ken hit that one with his reference ti "replaceable Patty". Adding to the problem (imho), If you have little "sweat equity" in the aircraft, you may be more inclined to test to destruction. quote:
ORIGINAL: britbrat I recently killed a very tired 10 yr old Ultra Sport 40 by stuffing it full of 60-size motor & trying to exceed 100 mph with it. I've seen this too often, with the one difference that there was little regard to the safety of others. quote:
ORIGINAL: can773 if you do a full throttle dive at the ground and haul in 30 degrees of elevator you cant expect your plane to survive long :-) I've witnessed many variations of this. Most common is the overpowered ARF performing a full throttle snap, literally resulting in the snapping off of the tail. Often blamed on poor quality ARF construction, I blame it on lack of throttle management. The "burning holes in the sky" mentality seems to have tracked along with the growing popularity of ARFs. Overall, I see a decline in disciplined flying (co-ordinated turns, throttle management smooth maneuvers etc.)
_____________________________
http://scalebuilder.org
