EASYTIGER
NY, USA Status: offline
quote:
ORIGINAL: MICRO-FLITE quote:
ORIGINAL: Andrew Zach - ...The facts, sir, just the facts.... *************** quote:
ORIGINAL: toolman2 I was present when a friend ran one of Micro Flight's throttled .010 engines. It was the best performing little gem I'd EVER seen! With RPM's in the high 29,000 and touching the 30,000 a couple of times and comming down to 5,000 also. The fuel (also available from him) was top notch and, using only castor oil, sealed the sleeve well. quote:
ORIGINAL: Skaliwag 11K# is realistic, anything lower is not consistant or reliable.. the flame goes out. Toolman2 is the co-designer of Steve Adams' (Scaliwag) .010 "Throttle Ring". Steve Adams said the COX TEE DEE .010 engine could not be made to idle below 11,000 rpm "...the flame goes out...." They were amazed, when they tached their MICRO-FLITE/COX TD .010 “R/C” ENGINE idling at 5,000 rpm. They were also amazed when they tached it hitting 30,000 rpm. When Toolman2 said, "It was the best performing little gem I'd EVER seen, it is obvious that MICRO-FLITE'S patented THERMAL EXHAUST THROTTLE has OVERALL excellent performance: Instantaneous throttle response, fully variable midrange, etc. The HIGH ACCLAIM coming in from the U.S.A. and overseas is that MICRO-FLITE'S throttle works just as well in the air as it does on the ground!!!! (See Michael Loft's 5-channel "1/8A" Pilatus Porter on our "1/8A" GALLERY at: www.micro-flite.com.) The MICRO-FLITE/COX TD .010 “R/C” ENGINE has ALREADY received very HIGH ACCLAIM from high tech universities, engineering schools and modelers. They have described the performance of the .010 "R/C" engine: "magnificent", "amazing", and "awesome"! The MICRO-FLITE/COX TD .010 “R/C” ENGINE is probably ALREADY the most highly praised small glow engine in the history of R/C modeling. We have posted some of this HIGH ACCLAIM on our web site (www.micro-flite.com) starting with page 3, under WELCOME TO MICRO-FLITE. There now is more HIGH ACCLAIM coming in from overseas. We will be posting this on MICRO-FLITE'S web site, soon. Roger Yes, well, I HAVE one and I can state with fierce conviction that all of the above claims are FALSE. It will not do what he says. It's a bald-faced LIE, and that's why he won't let anybody review it. The "high tech universities" did NOT use this engine...they got samples, found them inadequate, and threw them in a box. Like I said, the guy is a liar. A snake oil salesman. He does not even know Moby Grape like he claimed, I asked, he had never heard of him.
