RE: Showtime
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Showtime
Page: <<   < prev  86 87 88 89 90 91 [92] 93 94 95   next >   >>
Login
RE: Showtime - 7/3/2008 3:45:07 AM
bgfireman
Status: offline
Well, after some work I finally have smoke on my showtime. I went with a sullivan skywriter pump. I got a chance to test it out tonight in my front yard. The neighbors don't have to worry about the squiters tonight. I can't wait until I get the chance to try it in the air. Might even get a fes pictures.
Alan
_____________________________
Romans 3:23,
For all have sinned and come short of the glory of God.
(in reply to OK2Fly)
       Post #: 2276
RE: Showtime - 7/5/2008 2:03:36 AM
nappy99
Status: offline
I had a saito 100 in a showtime 90, it was way under powered, I just put in an OS120AX, we'll see how that goes
It doesn''t mean a thing.....if it doesn''t have a wing.
(in reply to aerobatixkid)
       Post #: 2277
RE: Showtime - 7/5/2008 11:45:40 PM
bgfireman
Status: offline
Mine has a saito 120s.
Alan
Romans 3:23,
(in reply to nappy99)
       Post #: 2278
RE: Showtime - 7/8/2008 4:36:00 AM
bgfireman
Status: offline
Has anybody had any aileron problems? My right one broke off about 6-8 inches from the end.(While in flight) Boy what a great flyer. I never could tell it by the way it flew. I'd not even got nervous if the others would have just said to land and told me what had happened. Instead of screaming something came off. Boy that gets your bp righ on up there. I did not see it come off. I heard a strange noise, but one of our other pilots saw what happened. They walked out in the bean field and found it. I have made repairs and am fixing to rehinge the aileron. She'll be ready to fly again soon.
Romans 3:23,
(in reply to bgfireman)
       Post #: 2279
RE: Showtime - 7/8/2008 7:21:46 AM
P-Diddy
Status: offline
quote:
ORIGINAL: bgfireman
Just to clarify: Did the aileron come apart or did the hinges fail and it simply came off? The stock CA hinges included with the ST90 are a known, well-documented problem and should definitely not be used.
Currently:Aviation/SD Yak 54 33%(3W70),UltraRC GilesG202(BCMA 40cc),T-Rex600N(O.S. 50 Hyper), MSH Protos 500
       Post #: 2280
RE: Showtime - 7/8/2008 12:02:06 PM
Zippi
Status: offline
Tower has this plane for $199.00. Does the plane still have the snapping issue when you yank on the elevator to hard ?
"It Ain''''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to P-Diddy)
       Post #: 2281
RE: Showtime - 7/8/2008 1:58:10 PM
bgfireman
Status: offline
P-Diddy,
Some of the guys at the field said that it looked like the hinge had failed.The one on the very end was broke in half along the hinge line. and the wood had seperated from the hinge on the next one in. Are you using robaart type hinges or CA hinges?
Zippi,
Mine was purchased used two months ago. I never saw the guy I bought it from fly it, but I feel like it is a newer version. Mine does not have that snap tendency that everyone talks about. Mine flies great at slow and fast speeds even with 2/3 of the aileron missing.
Alan
Right before the aileron broke my buddy did some beautiful rolling circles with it. Could this have weakend the hinges? Also do you think I should replace all the hinges.
< Message edited by bgfireman -- 7/8/2008 2:01:51 PM >
Romans 3:23,
(in reply to Zippi)
       Post #: 2282
RE: Showtime - 7/8/2008 5:40:28 PM
krayzc-RCU
Status: online
put those blue ca hinges are there i thnk sig make them they are great! that is just a typical ca hinge whie failure nothing else...... that is why its best not to fly anyones planes as when they start having issues it always revert back to:
smooth as silk!
       Post #: 2283
RE: Showtime - 7/8/2008 6:33:26 PM
OK2Fly
Status: offline
For some reason only some of the Showtimes snap.
I've replaced all the hinges in my plane because, one by one, they all failed. Luckily, I was able to find 'em and fix it before a flight.
Anderson
(in reply to krayzc-RCU)
       Post #: 2284
RE: Showtime - 7/8/2008 10:53:16 PM
HoverLoW
Status: offline
I got some hinges problems too. I replaced all for Dubro nylon hinges. Much more precision and durability.
I believe the snap tendence of some Showtimes is caused by CG problems. Mine was flying some months ago with an OS 160 FX without any mods. She was nose heavy and had a huge snap tendence.
Now I made some mods ( http://www.rcuniverse.com/forum/m_7598780/anchors_7598780/mpage_1/key_/anchor/tm.htm#7598780 ) and she does not snap anymore. CG is like manuals says (I think a little bit more tail heavy). Is the same plane. I Didn't buy a new one.
I love RCU!!!!
       Post #: 2285
RE: Showtime - 7/8/2008 10:58:29 PM
Pit-Viper 1
Status: offline
I had a snapping problem on mine on about the 3rd flight, turned out to be one of the Elev. servos was going bad and wasn't responding as fast as the other.
Shane
www.colorado-rc.com
(in reply to HoverLoW)
       Post #: 2286
RE: Showtime - 7/8/2008 11:03:35 PM
P-Diddy
Status: offline
quote:
ORIGINAL: bgfireman
P-Diddy,
Zippi,
Alan
After one of my elevators came off due to the hinges failing, I replaced them with Robart-style hinges. It doesn't take too much time, and they aren't that expensive, so I highly recommend replacing ALL of the stock hinges, especially if you, or someone else, are planning on doing any 3D maneuvers. The stock hinges are known for breaking apart at the hinge line and for separating, (plastic inner layer separates from fiber, porous outer layers).
       Post #: 2287
RE: Showtime - 7/10/2008 8:02:06 PM
gaboooka
Status: offline
Hello All,
I buy the ShowTime 4D 90 and SK 1.30 engine. This engnie is enough for 3D flying?
I like very good pull out from hovering. What is the recommended prop?
Not to heavy this enginse for ST 4D? 2.17lb whit stock muffler.
http://grcmodell.extra.hu/
