RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Page: <<   < prev  138 139 [140] 141 142 143 144 145 146 147   next >   >>
Login
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/27/2007 8:53 PM
DaddySam
Score: 110
Last Login: 6/17/2013
Status: offline
Winston
Great idea. I'll do it.
Sam
_____________________________
Daddysam
Corsair Brotherhood #26, Spitfire Brotherhood #7
Hide Signatures
(in reply to cimara)
       Post #: 3476
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/28/2007 1:08 AM
DaddySam
Score: 110
Status: offline
Before work, a bit of time spent on the Corsair. Got the wheel wells done, just need things to dry so I can sand the balsa and ply. I am going to work on the aileron mounts/tubes next. Thanks again for all the great advice.
Sam
Daddysam
Hide Signatures
(in reply to DaddySam)
       Post #: 3477
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/28/2007 4:07 AM
rt3232
Score: 113
Last Login: 6/20/2013
Status: offline
Hi Sam
What you have there looks good, and about the wing tips try checking everyouther page for about 40 page if not there back up on the one's you skipped, but it is there and if I get time in an evening I will try to help.
Cheers Bob T
Corsair Brotherhood #5
Hide Signatures
       Post #: 3478
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/28/2007 5:16 AM
cimara
Score: 100
Last Login: 4/8/2011
Status: offline
DaddySam
If your going to put lights in the wing now is the time to do that also .Its a pain to fish wire after its sheathed
http://www.greatdanepro.com/Pray%20For%20America/index.htm
Hide Signatures
(in reply to rt3232)
       Post #: 3479
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/28/2007 5:24 AM
ctflyboy
Score: 101
Status: offline
Daddysam,
I know for sure the wingtip mods are in here,cause when i did mine I posted pics on it,I just spent the last 1/2 hour looking for it and came up empty. I know there here but where? I'll keep looking I'll PM you when I locate them.
GEORGE
CORSAIR Brotherhood # 1
Remember, Man''s 2nd greatest adventure is FLYING, LANDING is his FIRST.
Hide Signatures
       Post #: 3480
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/28/2007 5:29 AM
cimara
Score: 100
Status: offline
Daddy Sam heres the link for the 1/8 scale wing tip mods http://www.rcuniverse.com/forum/m_964836/mpage_2/key_/tm.htm post 31 32 and 33 .You can use this to figure out what to do on the 1/5 scale
http://www.rcuniverse.com/forum/m_3109744/anchors_3581576/mpage_18/key_wing%252Ctip%252Cmods/anchor/tm.htm#3581576
http://www.rcuniverse.com/forum/m_3109744/anchors_4921713/mpage_61/key_wing%252Ctip%252Cmod/anchor/tm.htm#4921713
< Message edited by cimara -- 8/28/2007 5:40 AM >
Hide Signatures
(in reply to ctflyboy)
       Post #: 3481
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/29/2007 4:50 AM
duber3
Score: 105
Status: offline
hi everyboddy!!
I'm in the stage of balancing the plane, I would like to know how many weight you added
thanks!!
Hide Signatures
       Post #: 3482
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/29/2007 6:51 AM
DaddySam
Score: 110
Status: offline
Thanks Winston!
I got the rib T-7 sanded down 1/8", and am doing the final sanding before sheeting. What a pain! Makes me realize how much more careful I need to be when I fit the parts together. Anyway, I still need to install my aileron wire tubes, flap wire tubes, and do some thinking on the aileron linkage. I think I'll use the type that Chris Spangenberg used in High Flight. I'll either mount the servo to the hatch or to the rib with some ply reinforcement. Maybe some more progress tomorrow...
Sam
Daddysam
Hide Signatures
(in reply to duber3)
       Post #: 3483
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/29/2007 4:28 PM
rt3232
Score: 113
Status: offline
Hi Dubber3
On balancing if you build to the book with out lighting the tail end and you move the C/G fwd at least 3/8 and a stock G-62 you will nned some ware between 3 and 4 lbs,
Hope this helps
Cheers Bob T
Hide Signatures
       Post #: 3484
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/30/2007 8:41 PM
DaddySam
Score: 110
Status: offline
Here's a shot of the wing tip taper from to T-7. I should be near to sheeting.
Sam
Daddysam
Hide Signatures
       Post #: 3485
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 8/31/2007 12:43 AM
rt3232
Score: 113
Status: offline
Sam
Looks good so far, just keep the stright line, on the under surface all the way to the tip
Cheers Bob T
Hide Signatures
       Post #: 3486
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/1/2007 6:47 AM
timothy thompson
Score: 100
Last Login: 7/2/2008
Status: offline
more wing detail. its dark so i dont know how well these will look oops the esc is for my tf b-25
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by timothy thompson -- 9/1/2007 6:49 AM >
Hide Signatures
       Post #: 3487
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/1/2007 8:52 PM
DaddySam
Score: 110
Status: offline
I was thinking about the lead needed to balance the plane, and how the farther forward it's placed the less you need. What do you guys think about filling the dummy engine with the required lead shot and epoxy slurry, and then mounting the dummy engine on a plywood plate and then mounting that in front of the engine by means of three dowel stand-offs?
Just planning way way ahead.
Sam
Daddysam
Hide Signatures
(in reply to timothy thompson)
       Post #: 3488
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/1/2007 10:36 PM
rt3232
Score: 113
Status: offline
Sam
I am not fond of that mass in front of the engine in case of disaster, but that is just me, like I said the area between F1 and F2 looked to me as a safer place, and I know some have added to the inside of the cowl and glassed over the weights. so you will have to decide what will work for you, and maybe Tim, George, or Winston may have a better suggestion
Hope this helps
Cheers Bob t
PS got another good flight on my bird, but the programming was still a little off and the wind came up so put things off for another day, But it flies great right ware you point it and is vary predictable
< Message edited by rt3232 -- 9/1/2007 10:41 PM >
Hide Signatures
       Post #: 3489
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/2/2007 5:49 AM
RCPILOT78
Score: 100
Last Login: 5/12/2013
Status: offline
That is exactly what I did to ballance mine..your right the further up front the less weight needed......I hung lead weight to the back of the dummy engine which is mounted to an 1/8 inch ply backing.
Hide Signatures
       Post #: 3490
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/2/2007 6:05 AM
timothy thompson
Score: 100
Status: offline
you dont want to hang lead on the cowl. it is a non wt supporting piece. if it comes off you will crash. if you are using a g-62 look above the flywheel. You will see two bolts. you can add brakets to those and bolt lead dirctly to the motor. It works great!
Hide Signatures
(in reply to RCPILOT78)
       Post #: 3491
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/2/2007 6:18 AM
RCPILOT78
Score: 100
Status: offline
Your Right Tim...but if you remember my earlier post my dummy engine is not mounted to the cowl it is mounted on three 1/2 inch standoffs which extend from the firewall to forward of the engine.. I don't remember what post contained the photo it was way back ....there is nothing hanging on my cowl...thanks for reminding me to explain that feature...I just thought I would agree with the weight being less the further in front of the engine as possible....
Hide Signatures
       Post #: 3492
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/2/2007 7:18 AM
wulf190
Score: 105
Last Login: 6/15/2013
Status: offline
I think I mostly agree w/ Tim there RCpilot...You can get away with a little weight in the cowl ring I've found....I usually pour in some epoxy and some shot into the curved ring around the front, but I don't use a lot, cuz--like Tim says--it's a not weight bearing piece, and I don't want to hang all that weight on the cowl. I'll usually glass in the shot and epoxy, but I've never had any problem with it coming out or even loose....even after a long while. I just add some up there cuz it's about as far forward as a guy could get it. I'll add the majority of the weight into a hard mounted bracket usually where I can bolt it on. Too much weight on the cowl usually means loose cowl screws from vibration too.
Hide Signatures
       Post #: 3493
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 5:15 AM
cimara
Score: 100
Status: offline
GOt my Bomb pylons mounted today .I made them removable so if they cause adverse effects i can just remove them and use them only for show ( i hope they wont dont see why they would)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by cimara -- 9/3/2007 5:25 AM >
Hide Signatures
(in reply to wulf190)
       Post #: 3494
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 5:23 AM
rt3232
Score: 113
Status: offline
Winston
Ware are the pic's??
Cheers Bob t
Hide Signatures
       Post #: 3495
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 5:26 AM
cimara
Score: 100
Status: offline
Sorry Bob having a hard time getting them to upload
Hide Signatures
       Post #: 3496
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 7:21 AM
timothy thompson
Score: 100
Status: offline
more wing pics in better light. these are the bottom ive done nothing with the top yet
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3497
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 7:24 AM
timothy thompson
Score: 100
Status: offline
yes those are real screw heads. just the heads are used very little weight . ill finish most of the bottom details soon then work on the top. school starts tuesday so my summer is gone, oh well lots of flying and no crashes this summer. cimare nice job there!
< Message edited by timothy thompson -- 9/3/2007 7:25 AM >
Hide Signatures
       Post #: 3498
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 4:39 PM
rt3232
Score: 113
Status: offline
winston
Now that is a vary cool install and waiting to see how yout bomb's or tanks will look.
Weather hear is the pits wind so no flying till next sat.
Cheers Bob T
Hide Signatures
       Post #: 3499
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 9/3/2007 7:29 PM
cimara
Score: 100
Status: offline
thanks Tim and Bob .Still havent recieved the tanks yet from ziroli but they should work fine since its mounted in the scale location .
Tim how are you fasting all those screws with glue ? Looks good dont think i have that kind of patiance .
Hide Signatures
       Post #: 3500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
