RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Tower Hobbies
Logged in as Guest
Users viewing this topic: Canuck1
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: GROUP BUILD - Top Flite Giant Scale F4U Co... - 12/1/2005 1:42:36 AM
ctflyboy
Status: offline
trying to send pics.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Remember, Man''s 2nd greatest adventure is FLYING,
LANDING is his 1st.
(in reply to ctflyboy)
       Post #: 376
RE: GROUP BUILD - Top Flite Giant Scale F4U Co... - 12/1/2005 1:47:35 AM
ctflyboy
Status: offline
two more
Click for fullsize
Click for fullsize
LANDING is his 1st.
       Post #: 377
RE: GROUP BUILD - Top Flite Giant Scale F4U Co... - 12/1/2005 12:44:49 PM
rt3232
Status: offline
Keep up the good work
BobT
       Post #: 378
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/2/2005 2:45:07 PM
wulf190
Status: offline
George, looks like you've got the Forstner bits going good now. You'll dig how often you seem to use these things.
(in reply to rt3232)
       Post #: 379
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/2/2005 11:31:13 PM
ctflyboy
Status: offline
Mike
You were right, they certainly do come in handy,
Hopefully tonight I'll be able to mount the rear tailwheel and start running airlines up thru the fuse. I would like to close up the bottom by the weekend.
LANDING is his 1st.
(in reply to wulf190)
       Post #: 380
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/3/2005 1:03:20 AM
rt3232
Status: offline
George
If you are going to put your antana inside the fuse now is the time to run a plastic tube back thru the fuse, I just hot glue it in place, and just make sure it is clear of all controls, will try to catch you this w/e...
Bob T
       Post #: 381
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/3/2005 4:54:55 AM
ctflyboy
Status: offline
Bob, Am i ever glad you mentioned the antenna,I always seem to somehow FORGET this item,
Thanks for the reminder.
LANDING is his 1st.
       Post #: 382
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/3/2005 2:17:57 PM
wulf190
Status: offline
George, now's about the time you get to start thinking about your tailwheel doors too. I sure did like using the Nelson hinges back there. I just mounted a basswood strip underneath the hinges to give them something to screw in to. The tailwheel mount is easy, unless like me, you use the mongo tailwheel retract. Also, stock up on some heavy glass cloth and epoxy resin for the doors. I need more and have already gone through a bunch laying out the tail and gear doors. Did you get your wheels yet?
       Post #: 383
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/3/2005 5:43:10 PM
ctflyboy
Status: offline
Mike
I have not ordered the wheels, I was planning on asking you and the rest for opinions on the tailwheel itself.
DUE TO THE WEIGHT OF THIS BIRD, DO WE NEED AN ALUMINUM HUB FOR THE TAILWHEEL??
LANDING is his 1st.
       Post #: 384
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/3/2005 5:44:51 PM
ctflyboy
Status: offline
iT TOOK ME LONGER TO PUT THOSE BLIND NUTS IN, THAN IT TOOK TO INSTALL THE TAILWHEEL,
LANDING is his 1st.
       Post #: 385
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/4/2005 4:33:04 PM
rt3232
Status: offline
Good moring George
My personal experience with my first bird is no but I did bush it with some brass tubing, the mains yes and for a lite cheep wheel try the Sulivan "skylite" The only negitive I found was the nylon center hub, the hole was .005 under 1/64 off center, just set them up on the drill press and redrilled and brass bushed back to axel size.. Hope this helps
Cheers Bob T
       Post #: 386
RE: GROUP BUILD - Top Flite Giant Scale F4U C... - 12/4/2005 4:40:58 PM
rt3232
Status: offline
George
One outher thing I found helpful, ask you sig/outher for a bottle of finger nail polish (one ske don't like) then on screws. bolts, nuts, servoarm screws etc, put a dab on the side, so if it comes loos you can instantly see it... just a line on the side..
Cheers Bob t
       Post #: 387
