cimara
GA, USA Status: offline
quote:
ORIGINAL: bosssman in looking closely at your photos, it appears that the paint may be "blushing" - this happens when the ambient temperature is cool (below 60 degrees) and/or the humidity is high. I notice in the background you have snow on the ground? If you plan on painting water based paint in the winter, you need a heated area to at least 60 degrees, preferably 70 or above. I know its difficult to paint in winter (except here in SoCal ), but preheating where you intend to paint will help out considerably. Also, water based paints take a LONG time to dry out in cool/wet weather conditions to the point they can be sanded with some success..... randy Thanks Randy . No not snow here in Atlanta its a gravel drive going down to the basement .The temp was around 76 here dont know what the humidity was but will keep an eye on that .Learned on the primmer that any temp below 70 was not good for this water based paint.Defanatly more difficult to spray that PPG s acrilic enamel were you get the reducer for that temp your spraying at
< Message edited by cimara -- 3/30/2008 2:04:07 AM >
_____________________________
Winston Corsair BrotherHood #6
