RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 12:49:51 AM
rt3232
Status: offline
This is the lighting holes ha.. does any one know what (Avtive server pages error ASP0113. Script Timed out ) means if so help !
Next pic
Click to see fullsize image.
Click for fullsize
(in reply to rt3232)
       Post #: 51
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 12:59:02 AM
rt3232
Status: offline
next pic
Click for fullsize
       Post #: 52
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:18:16 AM
rt3232
Status: offline
JD hammer the next 4 pic's will help you with a muffler design, I did not get any over heating with this one
Bob T
Click for fullsize
(in reply to JDHammer)
       Post #: 53
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:28:32 AM
rt3232
Status: offline
next pic
       Post #: 54
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:38:38 AM
rt3232
Status: offline
next pic
Click for fullsize
       Post #: 55
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:47:19 AM
rt3232
Status: offline
next one
Click for fullsize
       Post #: 56
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 2:12:52 AM
bosssman
Status: online
Bob,
Are these pics of your CURRENT buildup, or of your previous GS Corsair? I should be posting pics later tonight as I am in the middle of sheeting the top of the fuse. I have been using one of my smaller Forstner bits to lighten the plywood around the stab mount and the rear tailwheel area.....
randy
_____________________________
"If you're in control, you're not going fast enough" (Parnelli Jones)
       Post #: 57
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:18:50 PM
rt3232
Status: offline
Randy
These are pic's of my current build, I have been using my notes of thingsI did or didnot do from the first build. If you need or want more in fo on any of the pic's I will try to accomidate ..I am going to try to post the pics of the retracts located in the c/section that shows the beams to close to the lower surface. they were trimmed 1/16 befor installing , but I am going to trim another 1/16'
Click for fullsize
(in reply to bosssman)
       Post #: 58
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:30:31 PM
rt3232
Status: offline
next pic
Click for fullsize
       Post #: 59
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 1:46:07 PM
rt3232
Status: offline
Well I finaly got all of my current pic's posted, I hope they will help those you who are in these stages. I would like to add a word of caution about this fwd part of the center section it MUST BE SQUARE particularly the l/g suport ribs. take your time, would like to see some ones else post there pic,s
Bob T
       Post #: 60
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 2:58:13 PM
Rocketman612
Status: offline
Bob,
Looking good.
The wing and build look similar to the 60 size kit. I found this stage to be about the hardest part in terms of keeping everything square and getting the proper alignment and fit of the retracts. I used CJ's and they only rotate 90 deg so there is a tradeoff between how far forward you want the extended wheel in relation to the wing leading edge (to prevent nose over and proper scale look) and how well the wheel buries in the wing when retracted. I believe the Larger CJ units also only rotate 90 deg.
Considering the importance of this area it's too bad TF didn't make a jig for us to use during this part of the build.
Pete
"Remember, all im offering is the truth, nothing more..."
Morpheus
       Post #: 61
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 7/17/2005 3:36:32 PM
D Bronk
Status: offline
quote:
ORIGINAL: Rocketman612
The wing and build look similar to the 60 size kit. Pete
YES way too many similarites` to call the 2 sizes of T.F. CORSAIRS totaly different.Lots can be done by scaleing up or down to suit the plane,that a person is working on,,,D.B.
Dave B. ------ Corsair Brotherhood # 11-------
I am a,#11,cause,,I`m 10% Better,than a perfect "10".
(in reply to Rocketman612)
