RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 12:58:14 AM
Darrell B.
Status: offline
Bob,
Can you give me their product number out of their magazine, so that I can have it when I call?
thanks,
Darrell
(in reply to rt3232)
       Post #: 151
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 6:58:53 AM
DaddySam
Status: offline
Hi Guys
I've been lurking too, and finishing up another project before starting this one. I've got pretty much everything but the pilot and the paint, and I'm not sure about what hubs I'll use for my mains. I just got the new Air Classics, and they have a great spread on a FG1D Corsair. Definitely the scheme I'm going to finish mine in. Still haven't figured the muffler yet for my G62. Should be starting to post progress here in a few weeks. Keep up all the good work everyone!
Sam
(in reply to Darrell B.)
       Post #: 152
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 1:28:31 PM
rt3232
Status: offline
Good morning
The number I have is TH2675 hope this helps
Bob T
       Post #: 153
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 3:31:11 PM
Darrell B.
Status: offline
Thanks Bob,
When I type that number in it comes up to the $10 gift coupon, but it still lists the plane as Discontinued. This is really frustrating. I hope that Top Flite is taking notes and will give us all a break again.
Darrell
       Post #: 154
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 3:56:35 PM
rt3232
Status: offline
Darrel
The only outher way that I kniw to possibly locate is,
Go to top flite' web page , Then it will ask you for your zip code, then it will list all of the local hobby shops that might have.
Bob T
       Post #: 155
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 4:29:44 PM
rt3232
Status: offline
Well after reading what every said about getting a mold for gear doors. I will post pic's at the end of the discription
HEAR IS WHAT I DID
Extra rib's and framing to make the square wheel well, then sheeted and did the layout, Note as there is no refferance for doors on the plans except the strut. I used the robart assy and wheel to give me the size,and location. Then I wanted a mold of the wing surface with the lay out. I put the smallest silk pin heads in each corner of all lines, covered with monocote, made a plaster mold I got vary small tix from the pin heads redrew lines with a scribe point and cleaned them with a #2 pencel vary fine point. cut out lower serface to the lines, monted gear assy..
Bob T
pic's to follow
Click to see fullsize image.
Click for fullsize
(in reply to Scott G)
       Post #: 156
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 4:52:23 PM
rt3232
Status: offline
Will try to do 2 I have a vary solw ISP
Click for fullsize
Click for fullsize
       Post #: 157
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 5:12:12 PM
rt3232
Status: offline
next two
       Post #: 158
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 5:20:17 PM
rt3232
Status: offline
willtry again
Click for fullsize
       Post #: 159
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 5:26:47 PM
rt3232
Status: offline
last one for now
Click for fullsize
       Post #: 160
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/1/2005 10:31:11 PM
fyredog
Status: offline
Nice
< Message edited by fyredog -- 10/1/2005 10:33:43 PM >
       Post #: 161
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/2/2005 1:44:11 AM
rt3232
Status: offline
When I built my first T/F G/S Corsair I did not pay much attentionto whare the axel was in relation to the leading edge, but I did not have strut or wheel well doors, the stock build puts the front end of the retract frame and the axel nut above the lower surface. On theis build I had to shave the beams allmost 3/16 to get everything inside the inside of the sheeting.
Now my question the axel is 35/64 behind the leading edge. Am I going to have nose over problems with this set up??
Bob T
(in reply to fyredog)
       Post #: 162
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/2/2005 2:15:30 AM
dionysusbacchus
Status: offline
Bob T
That looks perfect to me. Keep this in mind when installing gear. The further forward the gear axle is located in relation to the CG the less chance you have of nosing over, the down side is that it will have more of a tendency to ground loop. Ever seen a warbird landing and as it starts to slow the pilot runs out of rudder as the plane swings around? That is a symptom of poor axle location. When the axle is closer to the CG you will have a tendency to nose over but your ground handling and directional control will be much better. The trick is to find the sweet spot, your gear look very close to the scale location, I think it will do great.
Dion
