RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/15/2005 6:40:35 PM
wulf190
Status: offline
The plastic model is done after the modern version of it, short of the pilots name on the side. The original Dream plane was a birdcage canopy version and was completely different than this one, as Dion and others have so adequately pointed out in their threads. The red surrounding the markings was not used on the original, but is on the modern, restored plane which looks just like the scheme on this one. It is the one I'm using. You can find more about it at www.marinesdream.com
I'm not going to do a bunch more stuff to it than what I mentioned above, or has been done already, seeing it kind of fruitless to re-engineer a sport-scale model to a great extent to make up for inaccuracies. I knew about it's inaccuracies going in. Some liberties have to be taken with the panel lines on the wings due to it's deviation from scale as well. I've not had any illusions about competing with it, just want it to look adequate and fly nicely. I'll save better scale efforts for better scale planes than this one. It should be sharp when it's finished so I'm not too concerned with the re-engineering parts, i.e. drop down on the fuse underneath the cowl flaps, wing incidence, etc.. I saw the plane done nicely in the box scheme with stock TF equipment on it for cockpit, radial, etc. It was flying with a G62 and I went out and found one later that week as I was really impressed with the way it flew and looked for an everyday flier at the field.
Not looking forward to sanding that glass work. I'm glad it's in decent shape so far. I was a little concerned with how the cloth would smooth out over the gull section, but it really did nicely. The builder did a good job on the sheeting of the gull section. The glue joints are nice and tight and the wood is formed very well. The wood is all pretty stiff in there, so I'm glad for this fit. I also noticed that the stock fuse sheeting was replaced by the builder with softer Sig balsa which I was really happy about. Looks like someone else got clued in to the overstiff balsa sheeting included with the kit. I do have a bunch of extra sheeting left over now for Ziroli Stuka wing ribs!!
(in reply to rt3232)
       Post #: 201
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/16/2005 12:28:52 AM
rt3232
Status: offline
Well hear are some more pic of the gear door system
Frist one is with a torshin type spring, did not like it with the right wire fir the spring I had loose hinge pin.
Secound the hook up
Third is the spring I finaly settlrd on made from .042 wire 11/2 turns with 2 inch arms
Forth is location and ow it works
I will have some more naxt week
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to wulf190)
       Post #: 202
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/16/2005 1:43:47 AM
dionysusbacchus
Status: offline
Wow! Looks great, clean and simple. Nice job!
Dion
       Post #: 203
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/16/2005 6:11:51 PM
rt3232
Status: offline
One think I for got to mention is the bow is spring loaded into the pivit holes, with enough shaft to go thru 1/4 ply and thru the rib.
Dion Thanks for the thumbs up.
I am working on the right side and on the strut cover the hinge I have figured out but I am thying to come up with a simple strut atach piont
Bob T
       Post #: 204
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/16/2005 7:44:07 PM
D Bronk
Status: offline
BOB your supposed to be flying ,is it just as windy there ,as it is here???
_____________________________
Dave B. ------ Corsair Brotherhood # 11-------
I am a,#11,cause,,I`m 10% Better,than a perfect "10".
       Post #: 205
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/16/2005 10:08:28 PM
rt3232
Status: offline
YES
Bob T
(in reply to D Bronk)
       Post #: 206
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 12:46:11 AM
rt3232
Status: offline
Ok guys
Dave Bonk gave me an exelent idea for the strut door, and I am going to test it.. but I think there might be another way to do this, and be a little sturder, for the bigger builds
With all the viewers some of you have got to have some good ideas
Any help is appericated
Bob T
       Post #: 207
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 1:02:37 AM
rt3232
Status: offline
Dion
I was reviewing your thread ( Royal corsair 60 ) for some info on the way you did your strut door system, could not find any mention, but the pic shure show them working, so if you have a chance could you give me a discription of how you did them. I allways like to look at a coupla of ways to do some thing when I have never tackeled it..
Thanks Bob T
       Post #: 208
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 3:16:12 AM
ctflyboy
Status: offline
Hi There RT3232
I like your hatch for your airlines valve, do you have your on/off switch & kill mounted in there also? or are you planning a different hatch for them?
NICE JOB on those doors.
George
Remember, Man's 2nd greatest adventure is Flying
Landing is his 1st.
       Post #: 209
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 5:20:51 PM
wulf190
Status: offline
what a messy job, even the dog thinks so....
Click for fullsize
(in reply to ctflyboy)
       Post #: 210
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 7:32:15 PM
calibosss
Status: offline
I have my giant f4u nearly assembled, last thing is to build the flaps. the instructions say to use a 1/2 by 5/16 by 9 inch stick for leading edge of outboard flap. seems like this is wrong and should be 1/2 by 3/4 stick. anyone know whats up? did i miss somthing along the way? I got this kit when it came out and left it in the box for a cpl years. Did I miss an amendment to the instructions? pls help
       Post #: 211
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 10:02:49 PM
rt3232
Status: offline
Hi Caliboss
Asuming you are building a T/F G/C IThat will build ok but you have to be carful when beveling, as you can end up short
Bob T
(in reply to calibosss)
       Post #: 212
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair - 10/18/2005 10:06:30 PM
rt3232
Status: offline
Wulf190
Looks good, hope it was dry all tough a little fiber on the surface might make it stronger
Bob T
       Post #: 213
