F-18C Maiden    Gallery
Logged in as Guest
    Search This Thread
Printable Version
The NEW evoJet 160Vx - The Best Engine Made. Period. - RTF
Seller:  SinCityJets
Details:   $3,499.00   |  1/12/2012   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> F-18C Maiden
Page: [1]
Tower Hobbies Today's Special Offer! Brands Products
Login
F-18C Maiden - 6/27/2005 9:23 PM
piethein
Score: 100
Last Login: 1/3/2012
Status: offline
Hello All,
Maidened my 1/8 Hornet last thurday and got a tough lesson of making good approach and keeping the speed up.
The plane stalled and came through from about 21feet to runway, braking all landing gear.
I was supposed to take him to JWM, but I might not make it as all the gear parts are hand made and can not be bought from the shop. Anyhow the nose is allready ok, less a servo. Last night I cast some new parts from aluminiun and turned some new ones drom stock billet.
The oil shocks, I had made worked great and took the most of the shunt out, but still the fuse got couple of crack in the bottom.
The whole flight is in: www.neutro.fi/img/HN_ensi.mpg
Just the landing is in: www.neutro.fi/img/lasku.mpg
BR,
Jussi
Hide Signatures
       Post #: 1
RE: F-18C Maiden - 6/28/2005 4:50 AM
Silver182
Score: 100
Last Login: 12/19/2011
Status: offline
Jussi... never pull the power off until your low and over the runway! You probably had the throttle advanced just before you hit, but because of turbine lag you got no thrust.. Sorry to see that happen.. hope the fix won't be to difficult. I noticed you had wind also, which makes it more important to keep the power up. Don't worry about running off the runway, just preset the brakes to about 50% and touchdown with power. Looks like your going to need at least 1/3 to 1/2 power on finial. Also a lower landing profile will help also, fly it to the runway under power, power enough to land or go around then it's your choice.
Lee
Hide Signatures
(in reply to piethein)
       Post #: 2
RE: F-18C Maiden - 6/28/2005 9:43 AM
piethein
Score: 100
Status: offline
Yep. We had guite a wind.
In downwind and base it looked, that it is going to go too long, thus taking the power to idle.
Then in the final turn, a bit of too much of pull and the nose came up -> taking the speed.
Taking the gear out, she needs about 1/3 power! Lots of drag on those gears.
BR,
Jussi
Hide Signatures
(in reply to Silver182)
       Post #: 3
RE: F-18C Maiden - 6/29/2005 3:26 PM
Silver182
Score: 100
Status: offline
Jussi,
From the video it looked like you were flying from an improved runway of some sort.... just keep in mind you can and should preset the brakes so even if the next time you fly even on a day when there is no wind you won't be concerned about running off the end.... just remember keep the power up enough so if you need to go around you can... don't chop the power to idle until you are over the runway and low enough to flair for a soft landing.
This landing setup will prevent you from running out of airspeed and or beginning your flair too high! Think of landings with our heavy Jets as a controlled low, low, low approach that you can increase power and go around at any time! Make the landing when your just at right spot and hight over the runway, by finally reducing power for landing.
Best Regards,
Lee H. DeMary
AMA 36099
Hide Signatures
       Post #: 4
RE: F-18C Maiden - 6/29/2005 3:42 PM
Countryboy
Score: 109
Last Login: 2/7/2012
Status: offline
That's what you call making an F-18 into an instant Harrier. Looked like an almost vertical descent.
Hide Signatures
       Post #: 5
RE: F-18C Maiden - 6/29/2005 4:09 PM
SJN
Score: 105
Status: online
wow, that dropped like a rock!
I hope you get it all fixed again.
_____________________________
Sonnich Johannesen
Hide Signatures
(in reply to Countryboy)
       Post #: 6
RE: F-18C Maiden - 6/29/2005 11:16 PM
piethein
Score: 100
Status: offline
Well, it did not hover too well.
Just put in the last construction glue to join some parts and filled the shocks with oil. Maybe a new test flight in the weekend...
Usually when maidening jets, I fly some slow flight to get a feel for correct sink rate etc. This time we were running late, thus the slow test was forgot and I payed for it.
Next flight will be just slow flight and approaches.
BR,
Jussi
Hide Signatures
(in reply to SJN)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
13.281RCU1
