RE: Offical nitro tc3 thread
Tower Hobbies
Logged in as Guest
  Printable Version
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Offical nitro tc3 thread
Page: <<   < prev  24 25 26 27 28 29 30 [31] 32 33   next >   >>
Login
RE: Offical nitro tc3 thread - 9/29/2007 12:05:00 AM
ferrarimk13
Status: online
check if theres enough room there, between the engine and body posts to fit a rear exhaust pipe.
_____________________________
press Alt+F4 for a good time.
(in reply to djlectrix)
       Post #: 751
RE: Offical nitro tc3 thread - 9/29/2007 2:58:44 AM
mwstretch
Status: offline
Thanks chaseman81,
I have bought a Porsche 200mm body, seems to work better than stock. Going to remove the carb insert next and retune. Thanks foe the advise.
(in reply to chaseman81)
       Post #: 752
RE: Offical nitro tc3 thread - 10/4/2007 3:13:34 PM
chaseman81
Status: offline
quote:
ORIGINAL: djlectrix
Hi everyones i was find this post with the searching form and i wan't to know any issue about to make your NTC3 with a Rear pipe , i want to make my exau at the rear car for my pickup anyones have a good idea? thanks.
You'll have to get a new engine with the rear engine mount exhuast.
[qoute]Thanks chaseman81,
MWSTRETCH your welcome. Be perpared that car will be like a whole new deal once you take out the restrictor. You might want to run the older body till you get a handle on it.
       Post #: 753
RE: Offical nitro tc3 thread - 10/5/2007 1:50:18 AM
mwstretch
Status: offline
Thanks Chaseman for the info. You where right about it being a whole new animal. This thing hauls a** without the restrictor. Luckly I ran it in a big parking lot the first time I tryed it. Thanks again for the info.
Stretch
       Post #: 754
RE: Offical nitro tc3 thread - 10/5/2007 4:53:18 PM
chaseman81
Status: offline
LOL that's the same thing I thought when I did it. But I was on the racetrack racing, talk about a butt tightiner
(in reply to mwstretch)
       Post #: 755
RE: Offical nitro tc3 thread - 10/6/2007 1:58:52 AM
ferrarimk13
Status: online
does anyone have a pic of a NTC3 with a carbon fiber upper deck?
       Post #: 756
RE: Offical nitro tc3 thread - 10/6/2007 6:45:47 AM
rshooch
Status: offline
hey just bought one of these cars vary nice and vary fast. What is some good set ups for for parking lot running?? Shock oil weight springs tire ect just the basics thanks
Ryan
jammin x1, ofna lx1,ntc3,rs43evo, lst2, and micro-t
(in reply to ferrarimk13)
       Post #: 757
RE: Offical nitro tc3 thread - 10/8/2007 3:42:02 PM
cgflores
Status: offline
Hi guys.Hoping to get advice from you.Planning to buy the TC3 plus rtr or the traxxas nitro 4tec 3.3.which of these two is the best?speed and performance wise?planing to modify it in the future and go drifting too.
(in reply to streetuner)
       Post #: 758
RE: Offical nitro tc3 thread - 10/8/2007 4:21:43 PM
chaseman81
Status: offline
quote:
ORIGINAL: cgflores
I would go with the tc4 electric, if you plan on drifting. A nitro car isn't designed to run the way a electric driting car works. The nitro engine is different from an electric motor.
(in reply to cgflores)
       Post #: 759
RE: Offical nitro tc3 thread - 10/8/2007 5:41:22 PM
cgflores
Status: offline
Thakns for your reply.Im not really familiar with electric motor for rc but if Im going to go with the tc4,can it match the speed with the tc3 or 4tec?what modifications do I need to do with it?
       Post #: 760
RE: Offical nitro tc3 thread - 10/8/2007 5:48:45 PM
Suprachrgd82
Status: offline
quote:
ORIGINAL: rshooch
Ryan
Best upgrades for the car are anything that will lighten it, in addition to a good exhaust.
To get more speed and smooth torque band, portmatch the heaader to the ehxaust port. Add the RPM-tuned pipe.
Lighter parts include:
alum screws
MIP lightweight clutch bell
Ti tie rods, Ti hinge pins
graphite suspension upgrades (add rigidity)
Ti shock mounts
Lo-pro servos (futaba s9550)
alum outdrives/spool (strength)
Mip axles (strength)
alum pivot balls
3m chassis (strength/rigidity)
RPM ballcups
< Message edited by Suprachrgd82 -- 10/8/2007 5:49:46 PM >
You do not talk about Fight Club...
(in reply to rshooch)
       Post #: 761
RE: Offical nitro tc3 thread - 10/8/2007 6:50:54 PM
chaseman81
Status: offline
A tc4 electric holds the record of 147MPH! It was highly moded but speed is gained with the gear ratios between the spear gear and the pinion gear and the turns of the motor the lower the turns the faster the motor.
< Message edited by chaseman81 -- 10/8/2007 6:51:57 PM >
       Post #: 762
RE: Offical nitro tc3 thread - 10/8/2007 7:27:48 PM
ferrarimk13
Status: online
yeah, but is it official?
       Post #: 763
RE: Offical nitro tc3 thread - 10/9/2007 1:14:39 AM
cgflores
Status: offline
Do you know whats the top speed for the stock TC4?
       Post #: 764
RE: Offical nitro tc3 thread - 10/9/2007 2:26:19 AM
chaseman81
Status: offline
9 turn motor or brushless with the right pinion gear and spur gear 60mph. the main difference between electric and nitro is electric is now nitro has to build up and shift gears.
       Post #: 765
RE: Offical nitro tc3 thread - 10/9/2007 4:28:53 AM
