RE: Offical nitro tc3 thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Offical nitro tc3 thread
Page: <<   < prev  38 39 40 41 42 43 44 45 [46] 47   next >   >>
Login
RE: Offical nitro tc3 thread - 8/21/2011 7:56 PM
Jake C6R
Last Login: 2/26/2013
Status: offline
Check this one out...just finished trimming and cutting holes for the FT NTC3....came out pretty good!
Hide Signatures
(in reply to 378)
       Post #: 1126
RE: Offical nitro tc3 thread - 8/21/2011 8:56 PM
MrBlargMan
Last Login: 11/26/2011
Status: offline
Looks fantastic Jake! Very well done!
Hide Signatures
(in reply to Jake C6R)
       Post #: 1127
RE: Offical nitro tc3 thread - 8/21/2011 9:12 PM
Jake C6R
Status: offline
quote:
ORIGINAL: MrBlargMan
Thanks Blargman!
Here is what I came up with to cover the spur opening and the big hole where the steering servo goes, for my rally NTC3
That aluminum tape is pretty tough, I will see how it does. I went around the edges with fast drying silicone to make sure it stays stuck to the chassis.  If it doesn't work it is easy enough to scrape off the tape and silicone.
Hide Signatures
(in reply to MrBlargMan)
       Post #: 1128
RE: Offical nitro tc3 thread - 8/21/2011 9:29 PM
378
Last Login: 5/9/2013
Status: offline
I put some electrical tape over the holes in mine. The spur gears made a royal mess of the tape, they caught and ripped neat little holes in it, and once that happened it started catching on debris. The tape over the hole up front, however, is pristine, and has cut down tremendously on the amount of crud flying into the chassis. I also taped up the holes around the flywheel and the pull starter, but as with the spurs the tape over my flywheel got ripped off within minutes.
Edit: Our rally cars would do well with a set of head and tail lights, wouldn't you agree?
_____________________________
My stash:
1 rally modded NTC3, 1 HeliMax Axe CX Nano, 1 Hobbico NexSTAR.
Hide Signatures
       Post #: 1129
RE: Offical nitro tc3 thread - 8/21/2011 10:07 PM
Jake C6R
Status: offline
quote:
ORIGINAL: 378
Hey 378, I just went back and covered the remaining hole where the pull start used to be. Of course I can't cover the flywheel. It's all just an experiment, I'm sure if a sharp rock hits that tape just right it will tear a hole in it. If so I will go to plan B, as soon as I figure out what plan B is LOL.
Yes I think lights would be cool just for the hell of it. I was just playing around with this LED light kit I bought for lining up where to drill body holes. They mount on the posts and shine through the body. But they didn't work at all on that painted blue body, they wouldn't show through the undercoating. But they are damn bright! I think you can find a set of led headlights and tailights pretty cheap! Definately looks better than light decals.
Hide Signatures
(in reply to 378)
       Post #: 1130
RE: Offical nitro tc3 thread - 8/21/2011 10:19 PM
ntc3man
Last Login: 11/5/2012
Status: offline
nice job on your ntc3. i think i need to do that to my car too.
"If it runs right, dont mess with it."
Hide Signatures
(in reply to 378)
       Post #: 1131
RE: Offical nitro tc3 thread - 8/21/2011 10:21 PM
ntc3man
Status: offline
thanks for the advice.. i changed the filter to a nice oil foam filter and will still keep the exhaust cooler because i have found it has better fuel efficiency. thanks for the advice.
Hide Signatures
(in reply to 378)
       Post #: 1132
RE: Offical nitro tc3 thread - 8/21/2011 10:57 PM
378
Status: offline
quote:
ORIGINAL: Jake C6R
quote:
ORIGINAL: 378
My problem was the tape sticking to the spurs and getting torn that way. Your aluminum tape may not have that problem, I think the adhesive would give before the gear could tear it.
As for being able to cover the flywheel...<3 pull starts!
Six pulls, by the way. That's all I needed last time I ran mine.
Well I also want to run at night . I'm not sure if I want to put lights in my El-cam shell, though, as I'm pondering an entirely new shell. That one has too much of an overhang and I didn't get the post holes drilled very straight. I'm just not sure what I want to run...don't want a suby or evo, everyone else with an RC rally car runs those shells. Don't want a supercar, either, as those don't look right playing in the dirt. Hrm...I'm thinking Porsche 911, they ran those in Paris Dakar.
My stash:
Hide Signatures
       Post #: 1133
RE: Offical nitro tc3 thread - 8/22/2011 3:24 AM
Jake C6R
Status: offline
378, ha ha no way you will ever get me back into the pull starts! One time I ripped the hell out of my fingers on this buggy I was trying to start - I said screw this and put on a roto start backplate and I have never looked back! All roto start or starter boxes for me! LOL
Hide Signatures
(in reply to 378)
       Post #: 1134
RE: Offical nitro tc3 thread - 8/22/2011 4:22 AM
ntc3man
Status: offline
378, i did get a nice oil foam filter. i did keep the exhaust cooler because it definitely reduces fuel consumption. thanks for the advice!!
Hide Signatures
(in reply to 378)
       Post #: 1135
RE: Offical nitro tc3 thread - 9/3/2011 1:54 PM
Jake C6R
Status: offline
Still have not even tried out the rally NTC3!!! Work really gets in the way of my play time! I can't get them to understand I just want to get paid but not show up. Can't seem to get that arrangement worked out!
378, next weekend for sure. This one I'll be in Vegas...gotta win some money to buy more RC stuff! LOL
Hide Signatures
(in reply to ntc3man)
       Post #: 1136
RE: Offical nitro tc3 thread - 9/24/2011 1:33 AM
wminmi
Last Login: 3/28/2013
Status: offline
Kudos to those that have done the rally conversion
Just picked up a complete NTC3 with a .18 CV-R that I am going through (all torn down for cleaning) and I also got a mostly complete roller with it. Both are 2-speed of course.....now I know what I can do with all the spare parts and stock chassis
ALOT of RC''s.....and forever collecting more!!
Hide Signatures
       Post #: 1137
RE: Offical nitro tc3 thread - 9/24/2011 3:40 PM
Jake C6R
Status: offline
quote:
ORIGINAL: wminmi
Let's see it when you are done!
I finally got mine out and it was a blast! I took it out on this huge gravel and dirt parking lot. It's somewhat uneven but worked well for the rally set up! The car ran great and spit gravel and dirt with no problem. Powersliding was very fun! I am happy with the conversion, I never heard the chassis bottom out (but its already so scratched up I couldn't tell if it did)  so I think the clearance will be fine. Definitely worthwhile for a spare chassis!
Hide Signatures
(in reply to wminmi)
       Post #: 1138
RE: Offical nitro tc3 thread - 9/24/2011 8:15 PM
378
Status: offline
You won't hear it bottoming out over the engine. Trust me on that one. Don't worry about it scraping anyways, it's going to do that whether we want it to or not and it doesn't hurt anything.
My stash:
Hide Signatures
       Post #: 1139
RE: Offical nitro tc3 thread - 12/3/2011 6:53 AM
Charlie_MT2
Last Login: 12/13/2012
Status: offline
Hey guys check out my thread called Which Battery Pack For NTC3 RTR? I need some advice! Im sure one of you TC3 owners has gotten a new hump pack for their car. Which ones best?
Hide Signatures
(in reply to 378)
       Post #: 1140
RE: Offical nitro tc3 thread - 12/3/2011 3:31 PM
Jake C6R
Status: offline
Charlie, here is what I posted in your thread. If you want to see the battery installed look at the pix of my car in the previous page of this thread.
For bashing, I am really happy with the Stickman hump pack SRP2500-MUG.
http://www.amainhobbies.com/product_info.php/cPath/1_25_1480_54/products_id/18754/n/Stickman-RC-5-Cell-1-8th-Scale-NiMH-Receiver-Pack-60V-2500mAh-Normal-Style
It will go forever on a single charge. You don't need to change anything, as far as your receiver goes any battery with the correct voltage works fine. Obviously the better the battery the longer you can go between charges.I have one of these in my rally modded NTC3 and had one in my buggy also. For my racing NTC3 I use a flat pack for the lower center of gravity.
You won't see any receiver/battery charger combos because there are so many different receiver battery styles to fit so many cars and trucks.
As far as a charger goes you cannot go wrong with this one:
http://www.hobbypartz.com/thac6smbachw.html
Thunder AC6 will charge everything from NICD and NIMH to Lipos for $45! I have been using one for a long time and it is awesome.
I hope this helps and if you have any more questions ask away!
Hide Signatures
(in reply to Charlie_MT2)
       Post #: 1141
RE: Offical nitro tc3 thread - 12/3/2011 7:02 PM
378
Status: offline
quote:
ORIGINAL: Jake C6R
Incorrect. I found a combo in my LHS for 20 bucks that contained this charger and a matching 5-cell NiCD hump pack. Ofna's site, as well as Tower, make no mention of it though
If I can find the packaging I'll post a part number.
The shape of the pack doesn't matter. If it's a 5-cell pack a 6.0v charger will charge it, they all use one of two connectors. You only need to match cell count and cell chemistry, doesn't matter how many shapes of batteries there are and Rx packs all use standardized connectors.
My stash:
Hide Signatures
       Post #: 1142
RE: Offical nitro tc3 thread - 12/3/2011 10:31 PM
Jake C6R
Status: offline
Hey 378 how you been buddy?
Yes I stand corrected you can get one of those but the problem is it's only good for 6V.
If I was new to the hobby I still think I would get a little bit better charger that can handle all battery types and voltages as you grow in the hobby and buy more stuff, cause you know we always do! LOL
Plus it gives you the ability to adjust the charge amps and do charge/discharge cycling, has temp sensing ability, good peak detection, etc.
I would still spend a few bucks on the charger in my opinion,.
How is the rally car going?
Hide Signatures
(in reply to 378)
       Post #: 1143
RE: Offical nitro tc3 thread - 12/4/2011 6:14 AM
378
Status: offline
Two 6.0v nickle-based Rx packs are all I need to charge so I don't need a fancy unit. A wall adapter like the one I linked is perfect for me.
The car's going fine. It's been struck by a wave of laziness, though, I can't be assed to get out there and re-tune the engine. I have it set back to defaults because I pulled the carb, stripped it and cleaned it out to try to chase down an odd running problem.
< Message edited by 378 -- 12/4/2011 6:48 AM >
My stash:
Hide Signatures
       Post #: 1144
RE: Offical nitro tc3 thread - 12/4/2011 3:26 PM
Jake C6R
Status: offline
quote:
ORIGINAL: 378
Ha ha yeah I know what you mean, typically I mess with one car exclusively for a while then it sits. Lately I have been working on my Revo, my crappy 3.3 seized so I did the Picco .26 Red Dot conversion and I have about a quart through that one.
So I decided to get out the FT NTC3 and play with it, and the damn OS .12TR started giving me problems again. That engine screams when it runs great but ever since I bought it (used) it has been inconsistent. This time I tried everything I could and I could not get a good tune on it. The funny thing is that I previously sealed everything on it so I know there are no air leaks either. Anyway it's an old discontinued model and I am done with it so I bought a new Picco .12 7 port 51220 on eBay for $70. Should have it by next weekend to start the break in.
I'll let you know how it goes, I have read good things about them and for $70 you can't hardly go wrong! Not a good racing engine but should be great for parking lot bashing!
Hide Signatures
(in reply to 378)
       Post #: 1145
RE: Offical nitro tc3 thread - 1/30/2012 11:54 PM
378
Status: offline
Bumpdate: Finally got out there and retuned my engine. Damn thing's so happy and running so well I ripped the left rear tire right off the bead!
Nothing a little superglue won't fix, but I may have to chase the bead on the rim with the dremel a bit. I might have done a few speed runs and several donuts before noticing the tire was acting funny...
Good thing: The way I glued the tires means the tire itself is undamaged. I glued with four little dots around the circumference, staggered 45 degrees for inner and outer bead. So the tire didn't rip, the tiny little superglue dot just popped off. Did that intentionally as I wanted to be able to replace the tires but keep the rims.
My stash:
Hide Signatures
       Post #: 1146
RE: Offical nitro tc3 thread - 3/7/2012 2:59 AM
bronx boy
Last Login: 3/26/2013
Status: offline
picked up a megatech q16 engine last year from the megatech booth at the wram show for 29,00 new they clain 1.6 hp will it be to much engine for my tc3 diffs any help.from you tc3 gurus out there.
Hide Signatures
(in reply to 378)
       Post #: 1147
RE: Offical nitro tc3 thread - 3/7/2012 11:05 AM
378
Status: offline
It won't. First of all it's not going to be making anywhere near that. Except performance to be roughly in line with AE .15 they come with from the factory. Secondly, the diffs in mine are holding up just fine to off-road shenanigans and an OS 18 CV-RX, which is equal in output to low-end big blocks.
If it's a small block, chances are, it will be fine. You'll only run into diff problems if you're running big blocks.
My stash:
Hide Signatures
(in reply to bronx boy)
       Post #: 1148
RE: Offical nitro tc3 thread - 3/7/2012 5:23 PM
bronx boy
Status: offline
sounds great thanks for the heads up bud ill let you know how it works out
Hide Signatures
(in reply to 378)
       Post #: 1149
RE: Offical nitro tc3 thread - 4/20/2012 12:15 AM
tomst-maxx
Last Login: 10/17/2012
Status: offline
hey fellas i need some help. I am trying to get my tc3 running for the summer and for some reason i can get it started but while on the ground when i get past 30% throttle the car stalls. I can find any air leaks in it and i replaced the fuel lines. Any suggestion would be helpful thanks
If it aint brokew fix it!!!
Hide Signatures
       Post #: 1150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
