Iturnright
AZ, USA Status: offline
I have a Reflection Flatout, and i found it to be a good, but complicated build. The instructions manual could have been a little clearer, but it was adequate. As for the build itself, it took a long time. It seems like all the steps are simple and short, but there are quite a few of them. Additionally, I agree that the leading edge and trailing edge support tubes hardly contact the foam enough, but it is surely stronger than it is without them. One of the most time consuming things was the control rod linkages. As anyone else using these knows it took forever to jam those things that don't look like they fit at all into the very small control horn hole. I'm sure they'll never come out, of course I can't eithier. The landing gear are weak, a reinforcing bar would have done wonders, however, if you are flying anywhere without a smooth surface that doesn't matter too much, since the result is typically the same. All in all, good plane, long build for a foamy.
_____________________________
Kit capable, not trained.
