Ron Olson
Joined: 5/10/2002 From: Kalamazoo, MI, USA Status: offline
All props have some degree of cup but some add or take away cupping depending on what they want out of it. Think of it as if you were swimming. Cupped hands will help you go faster through the water than if you held your fingers out straight. There are many different types of cuts. You can cut the tongue area of the blades as some props from the factory can actually slow the boat down. There is back cutting, Barr cutting, named after Stu Barr, Texas cuts, and the list goes on. If you want to see what effects cutting could do to your props, if you have metal props take a felt-tipped marker or a machinists blueing and paint your props. Where the marking comes off the prop once you run the boat, this is the part of the prop that is doing the work. If you've seen that Octura has been coming out with a line of "M" series props, these are the ones that have been modified by Octura to remove unneeded prop area.
_____________________________
Member, Southwest Michigan Model Boat Club.
