jetpack
IN, USA Status: offline
True what Ron just said. Another thought is have you checked just the balancer for balance? Is that what came with the Great Planes balancer? Mines longer and has plastic cones. If the cones are out on your balancer, when you take your prop on and off of it several times and check it, the balance of the prop will show up a little different each time. It's good that you checked the drive dog slot before you started. Sometimes also, the lip of the bore on each side of the hub has a strange shape to it because of a burr from it being drilled and reamed, or a sink mark in the casting. This affects how the prop sits on the cones, and can throw the whole effort off on balancing. Where the cones seat the lip of the bore should have a good shape to it. Those cones are convienent to design to fit several size bores, but as far as being the best idea to locate something for true balance isn't the best approach. A more accurate way is to use just the rod which is a slip fit inside the bore and use no cones - but all that would need to be special made to fit proper and have the tips put on.
< Message edited by jetpack -- 5/18/2008 4:20:48 PM >
_____________________________
http://s231.photobucket.com/albums/ee247/jetpack_photos/
