Prop sharpening & other tips for new boaters
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Boats General Discussion >> Prop sharpening & other tips for new boaters
Page: [1] 2 3 4   next >   >>
Login
Prop sharpening & other tips for new boaters - 6/29/2005 1:05:06 PM
piper_chuck
Status: offline
Do I need to sharpen and balance my new prop?
The question of whether props need to be sharpened and balanced, and how it should be done comes up often. The answer to the first question, should they be balanced, is absolutely yes! Prop manufacturers sell unbalanced, dull props. In theory, they could balance and sharpen them before they sell them, but since boaters tend to "personalize" their props it's probably best that the manufacturers sell raw props. Shipping them raw also makes them less succeptable to damage during shipping and handling in stores.
So, what does a new person do with this raw prop? Well, there are several choices. The first is learn to sharpen and balance props. I provided links below to help those who might want to do this. Another option is perhaps you have someone local who can sharpen it for you. And the final option is many of the racing oriented online vendors offer a sharpening service. For a small fee, they will take that raw prop you order from them and send it to you sharpened, balanced, and polished and ready to put on your speedy new boat. If you're not excited about spending a couple hours with the prop, a few files, an assortment of really fine sandpaper, and a prop balancer, I heartily recommend letting someone else do it for you. If you're too proud to do this, consider the fact that many racers also use this kind of service.
I was going to extract information from a bunch of places and perhaps write an article on sharpening and balancing props. But if someone else has already done this, and better than I would have done, I'm just going to link to their information.
How do I sharpen and balance my new prop?
Here are some articles that describe prop sharpening, balancing, and modifications:
http://www.offshoreelectrics.com/prop_balance.htm
http://www.rcprops.com/TechNotes/rcprop_tech_info.htm
http://www.geocities.com/jwohlt5362/Propguide1.html
http://rcboat.com/prop.htm
Note, many props are made of an alloy containing beryllium. Dust containing beryllium is hazardous. Here is a link to a fact sheet: http://www.state.nj.us/health/eoh/rtkweb/0222.pdf When working with this material, it's important to wear a dust mask, and take steps to control the dust. I prefer hand tools, rather than a dremel, because it reduces the amount of dust generated, and the distance it spreads.
What about after run oil?
Working on this section. Until it's done, here's some links to get more information:
http://rcboat.com/after.htm
How can I find other boaters in my area?
As I was writing a reply about an upcoming race I realized many people reading this thread may be interested in finding other people to run boats with, and perhaps race. Here's links to 2 North American based boating organizations:
North American Model Boating Association (NAMBA) http://www.namba.com
International Model Power Boat Association (IMPBA) http://www.impba.net
How do you choose which one to join? Go to the web sites, find your district and look for the nearest club. Each of the organizations has strong and weak areas, pick the one that works for the place you live.
How do I choose the right size prop for my boat?
Here are some charts showing ranges for common boat sizes:
http://www.funrcboats.com/prop_chart1.htm
Octura prop chart that Ron posted:
http://www.pirespreto.com/octura_catalog3.htm
How much oil should I add to bring my fuel up to nn%?
To determine the quantity, do the following math...
Ounces of fuel times desired percentage = desired ounces of oil
Ounces of fuel times actual percentage = actual ounces of oil
Desired ounces of oil minus actual ounces of oil = needed ounces of oil .
Note that this will be a bit off because you have to pour off a bit of fuel to make room for the oil you add. This means you'll end up starting out with a lower amount of oil and fuel, throwing the calculation off a bit. However, rather than worrying about it, the above will give you a slightly higher than the desired oil percentage , which certainly won't hurt the engine...
Here's an example:
128 ounces times 18% = 23.04 desired ounces of oil
128 ounces times 12% = 15.36 actual ounces of oil
23.04 - 15.36 = 7.68 needed ounces of oil .
< Message edited by piper_chuck -- 9/14/2006 8:03:41 PM >
_____________________________
AMA 87959, IMPBA 19650 CD, IBDBG #2, local 12
There's A Reason I'm Behind You. You're About To Be Lapped!!!
       Post #: 1
RE: Prop sharpening & other tips for new boaters - 6/30/2005 3:05:42 PM
Ron Olson
Status: online
Those are excellent articles Chuck. I had those saved until my 'puter crashed about a month ago.
Another good article: http://rcboat.com/prop.htm
< Message edited by Ron Olson -- 8/10/2005 7:40:08 PM >
Member, Southwest Michigan Model Boat Club.
(in reply to piper_chuck)
       Post #: 2
RE: Prop sharpening & other tips for new boaters - 6/30/2005 5:54:29 PM
piper_chuck
Status: offline
No problem Ron, just trying to share information. I added your link to the list so everything is in one place. I also finished the opening paragraph, which had just ended in mid-sentence.
< Message edited by piper_chuck -- 6/30/2005 6:09:35 PM >
(in reply to Ron Olson)
       Post #: 3
RE: Prop sharpening & other tips for new boaters - 7/9/2005 6:11:15 AM
Ron Olson
Status: online
I just got the latest issue of RCBM today, Rick Eyrich did an excellent article on prop sharpening and balancing.
       Post #: 4
RE: Prop sharpening & other tips for new boaters - 7/27/2005 11:21:46 PM
piper_chuck
Status: offline
Lots of views, but no comments. Is this thread useful? Are there other tips that should be added?
       Post #: 5
RE: Prop sharpening & other tips for new boaters - 7/28/2005 12:25:27 AM
Davcruz
Status: offline
Chuck, I found it very helpful. I was a COMPLETE NEWB to boats 3 months ago and with the help of this forum I think I have been recategorized as just a NEWB.
       Post #: 6
RE: Prop sharpening & other tips for new boaters - 7/28/2005 1:31:11 AM
piper_chuck
Status: offline
Thanks for the feedback. If you think of things that would be useful to add to this thread, let me or Ron know. Have you hooked up with any clubs? The Old Dominion club in Chesapeake is having a race late August. If you've never seen one it's worth the trip, even if you're not ready to race yet.
(in reply to Davcruz)
       Post #: 7
RE: Prop sharpening & other tips for new boaters - 9/1/2005 1:02:30 AM
Nocturnal
Status: offline
Hey, I have a Octura X432, and I have a devil of a time getting up on plane. Would back cutting help fix this?
< Message edited by Nocturnal -- 9/1/2005 1:03:29 AM >
There's 10 types of people. Those who know binary, and those who don't.
       Post #: 8
RE: Prop sharpening & other tips for new boaters - 9/1/2005 1:42:00 AM
Ron Olson
Status: online
I don't know what you have it on. Most stock electrics and the mildest .12's should be able to turn an X-432 over. You may have problems elsewhere. Mention what the prop is mounted on, that helps a bunch.
(in reply to Nocturnal)
       Post #: 9
RE: Prop sharpening & other tips for new boaters - 9/2/2005 5:47:25 AM
Nocturnal
Status: offline
The prop is mounted on a Traxxas Nitro Vee via Dynamite .15.
       Post #: 10
RE: Prop sharpening & other tips for new boaters - 9/11/2005 10:44:58 PM
Ron Olson
Status: online
Here is an Octura prop chart to help you figure out what prop that you need with the pitch and diameter in both SAE and metric measurements:
       Post #: 11
RE: Prop sharpening & other tips for new boaters - 9/17/2005 5:55:40 PM
Ron Olson
Status: online
I have some prop charts that I finally found that I will send to some people at no cost, just PM or e-mail me your address. It's an older one so most of the newer props aren't on them. It does cover Octura, Prather and ABC props in all sizes. It shows the prop diameter and pitch in both SAE and metric numbers and expected speeds at several RPM ranges figuring in a 15% slippage factor. Copies are limited.
       Post #: 12
RE: Prop sharpening & other tips for new boaters - 9/23/2005 11:35:15 PM
ramos.marzan
Status: offline
looking for a place near georgia that i can send my props to get sharpen and balanced please let me know if you guys know of any thanx
jorge
       Post #: 13
RE: Prop sharpening & other tips for new boaters - 9/24/2005 5:17:34 AM
Ron Olson
Status: online
I don't know of any place near you to send them to but www.cmdracing.com sells them sharpened and balanced in Florida. Go into the Dockside and on the left is the Prop Wall. It's a .pdf that is updated daily in case you don't see what you need. You can request props also. I got 4 of them last winter, the service is great. If you look at the pix of the month, some of the ladies in there are Andy's employees!
As an addition to my posting above, I can not fax or e-mail the prop charts. Your name and address will be completely confidential.
(in reply to ramos.marzan)
       Post #: 14
RE: Prop sharpening & other tips for new boaters - 10/9/2005 2:44:36 PM
jetpack
Status: offline
I balance and sharpen my own props. I use a Magnetic Balancer for checking my progress, and use Bear Abrasive polishing sticks. These are six inch long pencil sized hard polishing sticks used to polish out mold cavities mainly in plastic injection mold shops. They come in all grit sizes, flat or round and can be shaped on a small grinder to help get the ends started for polishing whatever contour. After I have all of the surfaces rubbed down with these I will switch to wet/dry sandpaper and then compounds to lightly buff and polish.
Using the stones give you much more control on keeping the shape of the prop, and progress down past the sandcast or sandblasted finish faster than just sandpaper. Especially in the "kick-out" lip or "cup" area of the blades, where all the control is needed to help hold a good back edge.
These products can be found in such large machine tooling catalogs such as MSC in the abrasives sections.
http://s231.photobucket.com/albums/ee247/jetpack_photos/
       Post #: 15
RE: Prop sharpening & other tips for new boaters - 10/17/2005 10:10:13 PM
