fgbasher
Joined: 10/22/2003 From: Monroe Township, NJ, USA Status: offline
All FG tires will fit the Carson, Fire-Hammer or XTM cars. FG Part Numbers that work on the Carson, Fire Hammer and XTM. Some minor modifications may need to be done. 06011 Side guards l./r. each 1 pce. 06023 Servo saver A/B, 1pce. 06024 Servo saver pivot, 1pce. 06026 Steering rods M4, 2pcs. 06030 Steel balls 10 x 10,75, 4pcs. 06031 Roll cage, 1pce. 06032 Brace f. roll cage long/short each 1 pce 06033 Wing mount, 1pce. 06041 Pinion shaft 10 mm, 1pcs. 06042 Brake plate and square, 4pcs. 06044 Brake disks, 2pcs. 06048 Steel gearwheel 48 teeth big, 1pce. 06049 Clutch bell, 1pce. 06050 Plastic gear carrier 60 mm, 1pce. 06051 Dampening rubber, 4pcs. 06050 Plastic gear carrier 60 mm, 1pce. 06051 Dampening rubber, 4pcs. 06061 Rear axle mount left, 1pce. 06062 Rear axle mount right, 1pce. 06064 Differential housing, 1pce. 06065 Differential cover, 1pce. 06067 Differential gearheel B, 2pcs. 06068 Bevel differential gear axle, 1pce. 06075 Rear upper wishbone pin, 1pce. 06082 Gearwheel cover, 1pce. 06096 Shock retaining screw M5, 4pcs. 06099 Front shock mount, 1pce. 06104 Front driving axle 55 mm, 1pce. 06105 Wheel 1:6, white, 2pcs. 06106 Square wheel driver 9.5 mm, 2pcs. 06108 Off road tire stock M compound unmounted 06116 RC-plate Futaba, 1pce. 06135 Engine mount large, Zenoah/Marder, 1pce. 06414 Tire inserts f.6108/6409/6411, 2pcs. 06431 Steel gearwheel 16 teeth, 1pce. 06540 Receiver box, 1pce. 07088 Volume compensation f.shock absorb.,2pcs 07089 Shock piston 2 pcs. 07092 Spring plate 2 pcs. 07094 Swivel nut M16x1, 2 pcs. 07095 Adjustable ring 2 pcs. 07102 Front wishbone pin, 2pcs. 08092 Shock fastening pin/set collars 3 pcs. 08097 Front axle trestle A, 96 1 pcs. 08098 Front axle trestle B, 96 1 pcs. 08140 Alloy plate for front axle 1 pcs. 08348 Tank Solo complete, 1pce. 06027/05 Ball-and-sock.joint 6mm f.M2screw thread 06027/06 Steel ball 6 mm, 5pcs. 06029/01 Ball-and-socket joint 10 mm f.M8, 4pcs. 06076/01 Rear up. wishb.thread rods r/l 61mm,2pcs 06081/01 Ball 5/10x15 M5, 4pcs. 06100/03 Turnbuckle right/left, 32 mm, 2pcs. 06134/01 Engine mount small/G230 RC/Marder, 1pce. 07070/01 Rear shock mount 97, new, 1pce. 07087/02 Lower shock retaining, long 2pcs. 07103/01 Front upright FG Part Numbers that do not work on the Firehammer 06039 Gear carrier plate, 1pc. 06045 Brake operating shaft each 1 pcs. 06071 Alloy gear plate, 1pce. 06079 Rear driving axle, 1pce. 06080 Rear dogbone, 1pce. 06423 Gear wheel protect.f. 42/44/46/48 t.,set 06427 Plastic gearwheel 46 teeth, 1pce. 06428 Plastic gearwheel 18 teeth,1pce. 06481 Alloy shock absorber 2000 long, 1pce. 07087 Upper shock retaining, 2pcs. 08100 Front lower wishbone 1:5, 1pce. 06010/01 Alloy chassis Zenoah 1 pce. 06028/01 Track rod right/left 1:6, 74mm, 2pcs. 06066/01 Bevel diff. gear A, pluggable, 2pcs. 06069/01 Diff.driving axle, pluggable, 1pce. 06137/01 Bolt f. gear unit 24,5/26,5mm, 3pcs. 08100/01 Front upper wishbone 1:5, 1pce.
< Message edited by rcnutshobbies -- 6/29/2005 5:52:38 PM >
_____________________________
Large scale is the only way to go!
