willkline8
NJ, USA Status: offline
hi fellow 4-teccers I just got a nitro 4-tec- sweet city! Its crazy fast. But I have 2 handling problems- 1- I totally spin out on a parking lot surface! If I TOUCH the steering at speed, I do a full 360. I'm using stock shocks and springs and 50wt shock oil. I'm using venom hyper grip tires, but I heard the HPI X-pattern tires were good. Any one have suspension setup tips? I got sway bars, but I didn't want to try them just yet. Does anyone use a lot of front toe-in on the 4-tec? 2- there's a lot of slop in my steering. The steering doesn't always re-center itself when I let off the controller. I saw some post that recommended adding bellcrank bearings to make the steering more responsive- any other steering setup tips? This problem may or may not be related to the first... any advice would be appreciated. HOLLA -will
