Hi Tec Digitals
Tower Hobbies
Logged in as Guest
  Printable Version
Composite-ARF Extra 260 3m - RTF
Seller:  snobird
Details:   $4,900.00   |  8/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Hi Tec Digitals
Page: [1]
Login
Hi Tec Digitals - 1/6/2002 7:32:03 AM
BAGOSTIX
Status: offline
Has anyone heard of people having lock up problems with the Hi Tec 5945MG servos? I have a ton of these and have heard that at full deflection they lock up... let me hear the reviews, good or bad..
_____________________________
Advanced Composite Manufacturing (ACM)
www.acmuav.com
rick@acmuav.com / bagostix@aol.com
Rick (BAGOSTIX) Broussard
       Post #: 1
servo - 1/6/2002 8:05:33 AM
Diablo-RCU
Status: offline
I just got finished setting up my Cap with 8 of these servos. I have been running them for at least 4 hours during the programming. No lockups yet and not a single problem.
(in reply to BAGOSTIX)
       Post #: 2
hi-teck servos - 1/6/2002 8:10:36 AM
Radman
Status: offline
I run the 5645's ( a step below what you have) After a seasons worth of flying i never had one problem with the digitals. For the money i don't think they can be beat.
       Post #: 3
Hi Tec Digitals - 1/6/2002 8:22:17 AM
mglavin
Status: offline
Stix
Some of the original HiTec Digi's had an amplifier that could be overdriven if I recall the terminology correctly. For instance anything above 120% on ATV would or could cause this problem to surface. HiTec did upgrade some of these. If you suspect that there maybe a problem ship them to HiTec for an upgrade or at least a checkup. The servos carry a two year warranty.
I have been using them with no problems..
< Message edited by mglavin -- Jan 6 2002 3:50AM >
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 4
Hi Tec Digitals - 1/6/2002 9:38:34 PM
Kickin Chicken
Status: offline
Hi Guys,
Since ya'll talking about Hitec Digi's locking up, I need some advice also,I have ordered a HS5645 Hitec/Jr to be used with a Futuba GYA350 gyro and a Futuba 9c, after ordering I read somewhere about failsafe programming only with Hitec/Jr and such, should I send it (servo) back and get a Futuba/Hitec setup? Christmas gift certificate was burning a hole in my pocket and wasn't thinking too clearly.
Kick'In Chicken
Leesburg,Georgia
       Post #: 5
HiTecs - 1/6/2002 9:45:09 PM
BAGOSTIX
Status: offline
Thanks fellas, I was bummed that I had all these servos with so much torque but couldnt use them without a certain degree of apprehension.. I appreciate the replies..
www.acmuav.com
       Post #: 6
Hi Tec Digitals - 1/6/2002 10:35:08 PM
mglavin
Status: offline
Kick'In
[QUOTE]Originally posted by Kick'In Chicken
Hi Guys,
[/QUOTE]
Not a 100% sure on what your saying here, but I'll try and offer what I do know.
HiTec Digitals have an onboard servo fail-safe feature. This feature is usable if you have the HiTec servo programmer. This feature will work with any TX or radio system. If you have a PCM RX then you will not need to even consider using the on board fail-safe, i.e. it would be redundant.
As far as the application goes Hitec/JR, the only difference is the servo wire pigtail. The HiTec/JR servo pigtail will work fine with a Futaba RX, simply pay attention to the color code when installing the servo plug.
Michael Glavin
       Post #: 7
Hey Mike - 1/7/2002 4:10:13 AM
BAGOSTIX
Status: offline
Have you used the programer? I saw they came out with one recently.. and another question, do these make as much noise as the JRs?
www.acmuav.com
       Post #: 8
Hi Tec Digitals - 1/7/2002 5:17:28 AM
mglavin
Status: offline
Yes, I have the programmer/servo tester, Its a very nice piece of equipment. In addition to being able to program HiTec Digitals the programmer can be used as setup and testing device on all servos regardless of brand. I use it to setup servo throw and centering prior to complete a radio installation. The programmer comes in a aluminum case much like a charger and has an onboard power supply/NiCad battery source.
The HiTec Digitals make a different noise, less obnoxious than JR, but still present. Sounds like its moving a little faster and and a higher pitch jitter but at a lower noise level.
Michael Glavin
       Post #: 9
who's who? - 1/7/2002 5:24:15 AM
BAGOSTIX
Status: offline
Who's selling the programmer Mike? I checked with Servo City no joy..
www.acmuav.com
       Post #: 10
Hi Tec Digitals - 1/7/2002 6:05:05 AM
Kickin Chicken
Status: offline
Thanks mglavin,
Sorry for not being completely clear but your answer was right on,
I will be using a 9c pcm and didn't want this servo go south around failsafe - I don't use this feature I rather crash on my own.
Kick'In Chicken
Leesburg,Georgia
       Post #: 11
Hi Tec Digitals - 1/7/2002 6:13:18 AM
mglavin
Status: offline
Rick
I purchased the HiTec programmer from my LHS. They maybe on backorder at other locations. I understand the initial order was depleted on release.
Michael Glavin
       Post #: 12
LHS? - 1/7/2002 6:31:42 AM
BAGOSTIX
Status: offline
I'm not clear on LHS thanks Mike
www.acmuav.com
       Post #: 13
Hi Tec Digitals - 1/7/2002 6:35:13 AM
mglavin
Status: offline
LHS = Local Hobby Shop
Michael Glavin
       Post #: 14
>>>> - 1/7/2002 6:48:23 AM
BAGOSTIX
Status: offline
OIC derrrrrrrrrrrrr thanks
www.acmuav.com
