RE: Bdavison's E-flite Blade Assembly
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Bdavison's E-flite Blade Assembly
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Bdavison's E-flite Blade Assembly - 12/26/2005 2:51 AM
hellomynameisdookie
Score: 100
Last Login: 9/27/2007
Status: offline
Anyone have a link to the infamous Bell Hiller upgrade head?
Hide Signatures
(in reply to Doomgaze)
       Post #: 226
RE: Bdavison's E-flite Blade Assembly - 12/26/2005 6:35 AM
dragoljub
Score: 100
Last Login: 5/9/2006
Status: offline
I have had no trouble hovering with and without the BCP body, however you can’t really avoid the tendency for the heli to slide left. It will never rise perfectly vertically, but you can get damn close! : ) Try lifting off while holding the cyclical stick slightly to the right, it will seem to tip right but as you get into the air it will all balance out and you are back at center stick hovering! KEEP PRACTICING and GOOD LUCK!
Hide Signatures
(in reply to hellomynameisdookie)
       Post #: 227
RE: Bdavison's E-flite Blade Assembly - 12/26/2005 6:37 AM
dragoljub
Score: 100
Status: offline
Bell Mixer Upgrade Kit: BCP
http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=EFLH1170
Hide Signatures
       Post #: 228
RE: Bdavison's E-flite Blade Assembly - 12/26/2005 2:10 PM
hellomynameisdookie
Score: 100
Status: offline
TY, Sir.
Hide Signatures
(in reply to dragoljub)
       Post #: 229
RE: Bdavison's E-flite Blade Assembly - 12/27/2005 6:32 AM
zooland1
Score: 100
Last Login: 10/10/2007
Status: offline
dragoljub
Any idea what the extra links are for and how they hook up? I've heard they're an improvement but don't understand how they would be set up.
_____________________________
Helicopters can't fly. They're just so ugly the earth repels them. -author unknown
Hide Signatures
       Post #: 230
RE: Bdavison's E-flite Blade Assembly - 12/27/2005 7:22 PM
dragoljub
Score: 100
Status: offline
Sorry, I don’t know about the bell mixer. I don’t actually have them installed on my heli.
Also off topic,
The T-REX 450 is awesome from what I can tell. I have only seen how it can be flown; you can see some amazing stunts here:
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=600
the videos are simply amazing!
and as far as the internet support for these things goes... well its great.
the BCP seems to have no one interested in sharing their little flight secrets (with this forum as the exception)
but the T-REX has many sites with lots of information.
one being:
http://www.trextuning.com/
and a good review at: http://www.rcuniverse.com/magazine/article_display.cfm?article_id=572
sorry if its a bit off topic but yea.. its awesome. I am seriously considering this as my next heli. I want to build it, and I want to fly it!
also brushless is just DAMN cool!
-d
Hide Signatures
(in reply to zooland1)
       Post #: 231
RE: Bdavison's E-flite Blade Assembly - 12/27/2005 8:57 PM
Dragonuv
Score: 100
Last Login: 4/27/2006
Status: offline
I have exactly the same problem as you. As long as tail is facing me, I am OK. I can fly forever. However as soon as I attempt to turn the heli sideways, it would usually result in a crash. soo frustrating.
Hide Signatures
(in reply to Pilot352)
       Post #: 232
RE: Bdavison's E-flite Blade Assembly - 12/29/2005 3:32 AM
zooland1
Score: 100
Status: offline
dragon
Most people struggle with control in anything other than tail in. Only takes a minor mistake going the wrong way and not be able to save it. Keep practicing and soon it'll just click. I just keep practicing on the sim and then realize I'm actually doing it. I had a couple major saves this weekend and didn't even realize what I had done until I brought it down safely. Also wasn't so lucky a couple times and snapped the boom support off twice. Ca'd it back together and put it back up. That was the only damage all weekend, so I must be improving. I think the biggest key for me was to learn it only takes a tiny bit of stick to make a huge move. My initial tendancy was if I made a bad move to overcompensate and make a worse move until I was out of control. Another thing I had to overcome was thinking if I kept close to the ground I could bring it down and save it. More throttle, more air, more time to recover, good. Less throttle, ground rises into chopper quickly, bad.
Hide Signatures
(in reply to Dragonuv)
       Post #: 233
RE: Bdavison's E-flite Blade Assembly - 12/30/2005 1:36 AM
swatr6
Score: 100
Last Login: 1/17/2006
Status: offline
i have been following these steps as far as tracking and everything. i have gotten pretty good at the sim that i got. so i tried flying my blade a few hours ago. it seems that the tail wants to spin the one side. i tried adusting the trim for the tail motor. but i can tell if that helped or not. any help on what to do next?
Hide Signatures
       Post #: 234
RE: Bdavison's E-flite Blade Assembly - 12/30/2005 3:43 AM
btoby
Score: 100
Last Login: 3/9/2010
Status: offline
rtfm!
Hide Signatures
(in reply to swatr6)
       Post #: 235
RE: Bdavison's E-flite Blade Assembly - 12/30/2005 6:55 AM
tom_sandiego
Score: 100
Last Login: 3/21/2010
Status: offline
rtfm What's that mean?
Tom
Hide Signatures
(in reply to btoby)
       Post #: 236
RE: Bdavison's E-flite Blade Assembly - 12/30/2005 7:31 AM
reiffron
Score: 100
Last Login: 3/15/2010
Status: offline
has anyone tryed using 3 hitec hs-55 or even better some hs-56 servos on a blade cp? thinking a better servo with more power and better centering might make the ol blade a little better flyer? also is there a way to install a heading hold gyro and still use the original 4 in 1?
Hide Signatures
(in reply to tom_sandiego)
       Post #: 237
RE: Bdavison's E-flite Blade Assembly - 12/30/2005 11:26 AM
btoby
Score: 100
Status: offline
read the freekin manual
Hide Signatures
(in reply to reiffron)
       Post #: 238
RE: Bdavison's E-flite Blade Assembly - 12/31/2005 3:08 AM
Reinforcements
Score: 100
Last Login: 1/20/2006
Status: offline
Okay. So i got a new set of blades for my , ur, Blade.
The thing is now, with two different batteries, (one of which I know had been overcharged at one point by the previous owner), my heli flies like crap.
And Im not talking baout how bad I fly.
When it's just hovering, at maybe half throttle, it will just drop about 4 feet or so, then take back off again, kind of slowly.
Also, it seems that adding some right stick to the left, makes my motor slow down audibly.
Is it the :batteries? 4in1? Motor? I could really use some help here
(I just changed to the spare motor I had, because the thing between the wires lit on fire during a flight.)
Hide Signatures
(in reply to btoby)
       Post #: 239
RE: Bdavison's E-flite Blade Assembly - 12/31/2005 4:42 PM
emtffkev
Score: 100
Last Login: 8/8/2009
Status: offline
Hi everyone, I am new to these forums. I just recently got a Blade CP for Christmas, and have since been tinkering around with it, but I am too nervous to get it off the ground. I just went out today and picked up the training gear, but unfortunately it doen'st come with any instructions on how to mount the gear to the skids. Anyone know of some instructions or even just a picture of a BCP with the gear on so I can see how it is done?
Hide Signatures
(in reply to Reinforcements)
       Post #: 240
RE: Bdavison's E-flite Blade Assembly - 12/31/2005 5:05 PM
Jhelfire
Score: 100
Last Login: 12/4/2006
Status: offline
quote:
ORIGINAL: emtffkev
Emtffkev,
Go to this site and it'll show you how to install the training gear. http://www.willshobbies.com/blade_training_gear.html Jerry
Hide Signatures
(in reply to emtffkev)
       Post #: 241
RE: Bdavison's E-flite Blade Assembly - 12/31/2005 5:41 PM
emtffkev
Score: 100
Status: offline
Thank you Jhelfire, That was exactly what I was looking for.
Hide Signatures
(in reply to Jhelfire)
       Post #: 242
RE: Bdavison's E-flite Blade Assembly - 1/3/2006 11:36 PM
glasshole03@yahoo.com
Score: 100
Last Login: 12/4/2007
Status: offline
hey ,i put the twin tail motor bracket on my blade cp , once i trimmed it out a little . it hovers rock steady. and i have only been flying a helicopter two months. ( i should say hovering. not yet able to fly. but it won't be long).
Hide Signatures
       Post #: 243
RE: Bdavison's E-flite Blade Assembly - 1/4/2006 1:25 AM
dwr
Score: 100
Last Login: 8/27/2009
Status: offline
BDavison, thanks for all your efforts on this thread, It has been very helpful. Got a BCX a month ago and learned a lot as a zero time heli operator and just had to try the BCP. Now I can hover the BCP but have a long way to go Qestion on the BCP. Is the spindle supposed to float in the center hub? Mine can shift about 1/32 to 1/16th of an inch. Could this cause changes in head vibrations that I have observed during a single flight? Seems like I can start out hovering with little vibrations but later in the battery run after several hovers and no crashes there seems to be more vibrations. Anyone else find this? another question. I have not
experienced any sticking in the head at all. I got the machine about Dec. 28th. The grip was assembled with the larger washer with the ridge on it against the bearing. The I.D. of that larger washer clears the O.D. of the spindle. The small washer tightens against the face of the spindle. I do not understand how switching these washers could fix a sticky head? I don't have the problem but I'm curious about it???
Hide Signatures
(in reply to glasshole03@yahoo.com)
       Post #: 244
RE: Bdavison's E-flite Blade Assembly - 1/5/2006 4:27 PM
mungusaurus
Score: 100
Last Login: 11/16/2006
Status: offline
Bump
Hide Signatures
(in reply to bdavison)
       Post #: 245
RE: Bdavison's E-flite Blade Assembly - 1/6/2006 12:33 AM
dwr
Score: 100
Status: offline
Well guess I found the source of changes in vibrations during a single battery run. The silicone tubing that holds the tail rotor blade in place can back off pretty easily and allow some movement in the tail rotor blade. This can cause vibrations that transfer into the boom and main rotor. I found that Robart air line material makes a good snug fitting replacement for the stock tubing. Runs are more consistent now that the rotor blade stays in exactly the same place.
Hide Signatures
(in reply to dwr)
       Post #: 246
RE: Bdavison's E-flite Blade Assembly - 1/9/2006 12:03 AM
zumzum5150
Score: 106
Last Login: 3/18/2010
Status: offline
hi guys,
My very first Heli. I am a newbie to flyin but not to RC. She's still in the box, won't touch her until the the training gear stuff arrives. My question is, will a TP 2cell 1320 lipo pack have enough to power the BCP? LHS has one for $15 can't pass up a deal. I hated the ratchet feel on the trottle so did the fuel tube mod. Feels way better. i can't wait to start hoverin!
apprreciate the help!
Hide Signatures
(in reply to dwr)
       Post #: 247
RE: Bdavison's E-flite Blade Assembly - 1/9/2006 3:42 AM
hellomynameisdookie
Score: 100
Status: offline
With the 2 cell lithiums you need to run an 11t pinion on your main motor to increase the headspeed to compensate for the lower voltage of the battery. If not, you'll struggle for headspeed and have a tough time with the heli.
If you decide to go 3 cell, run a 8 or 9t pinion.
$15 is a steal, so even if you don't need it, scoop it up!
Hide Signatures
(in reply to zumzum5150)
       Post #: 248
RE: Bdavison's E-flite Blade Assembly - 1/9/2006 7:30 AM
zumzum5150
Score: 106
Status: offline
dooks,
thnk u for replying to my post. I've gone ahead and picked up the 2S aswell as a 3S pack. I do have another question for you though. It was a nice xmas this time around so i've got xtra cash to play with. I was thinking of picking up the
Eflight alluminu swash plate
Aerobatic kit
DD rear motor set up
or dual motor set up
Now, will these options make it easier for me to learn to hover or should I stay stock first? I haven't even taken the darn thing out of the box. I've been accustomed to ugradeing all my Nitro trucks and cars beofore I can even break-in the motors. Before the heli i was into nitro bikes now i've dropped that and eagerly siked on flying.
thnx
quote:
ORIGINAL: hellomynameisdookie
Hide Signatures
       Post #: 249
RE: Bdavison's E-flite Blade Assembly - 1/9/2006 9:57 PM
LongRifle
Score: 100
Last Login: 4/3/2007
Status: offline
How tight do you tighten the screws inside the blade grips? I noticed one of my blade grips has some play in it (can pull it away from the main shaft) and the other does not. It doesn't seem like the screw goes in when you tighten it, but the play disappeared.
Hide Signatures
(in reply to awdtsi)
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.732RCU1
