hellomynameisdookie -> RE: Bdavison's E-flite Blade Assembly (1/9/2006 10:03 PM)
The aluminum swash is a great upgrade, and if nothing else it looks awesome on there peeking out from atop the canopy! Staying stock or not is up to you. I know people that are flying well doing basic things like ff and figure 8's with the stock motor and battery. What you need to decide is what cells you're going to use, because you don't want to be swapping out pinions constantly because you are changing battery packs with different voltages. Personally, I don't know if the DD is worth it. I have it on mine and as it does seem to have more push under more input, but I'm thinking about going to the stock setup with the carbon tail. The carbon tail is definately a good upgrade from the stock plastic. A bit more response. My personal advice would be to try the carbon tail first. If you decide to try the DD in the future I'm sure you'll have no problem at all selling the tail, but it doesn't cost much so it's no big deal anyway. The DD setup is also a bit heavier so it will be a bit trickier getting good balance, even with the batteries as forward as possible. The tail boom really should be shortened a little bit to compensate for the extra weight. Definately get the aerobatic kit, you'll use everything in it eventually. Right now you can put on the heatsinks and when you progress you can swap out the motor for the lower pinion and use lipo's, plus it's got a set of blades and you can never have to many extra sets of blades laying around.
