choppersrule
IN, USA Status: offline
Shaun, It can be a tedious process adjusting the proportional and gyo setting. First, turn the gyro gain all the way to the left/off. Plug in the battery, wait for the 4 in 1 to arm. Throttle trim about mid way setting. Advance throttle slowly and watch if the nose of the heli want to turn left or right. If the nose turns left, then turn the proportional gain to the right, you must disconnect the battery each time you make an adjustment to the proportional mixer. Repeat process as many times as needed to get the heli from rotating left or right. Next, it's time for the gyro setting, this can be done without disconnecting the battery each time you make an adjustment. Turn gyro about 1/4 turn to the right, throttle up slowly and lift off just a foot or so off the ground and see what she does. Keep increasing gyro gain until you feel it's right for you, we all have different skill levels and feel for flying. When increasing gyro setting, if the tail starts to wag like a dogs tail, even slightly, then the gyro gain is set to high. Back of the setting just a tiny bit at a time, until the wagging goes away. It could take 5 or 10 minutes to go through the process. But it makes the Blade much more stable and flyable. Hope this helps, Choppersrule
_____________________________
"Flying is learning how to throw yourself at the ground and miss"
