RE: Bdavison's E-flite Blade Assembly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Bdavison's E-flite Blade Assembly
Page: <<   < prev  10 11 12 13 14 15 16 17 18 [19]
Login
RE: Bdavison's E-flite Blade Assembly - 8/26/2006 1:18:47 AM
pitch
Status: offline
hehe trying to picture that one...i have hit it in the kitchen and it was a mad scramble to get back to normal but i am trying to figure out how you hit it with your leg???
so i came home from work had a little daylight left thought i would practice more...everything was going not too bad did not crash just a couple not so soft landings but all were on the skids...then i took it up about 4 feet and my neighbors shed decided to jump out and whack my heli...the nerve...was a dumb place to put a shed right in front of the heli!? after that it was getting too dark and i ended it...wife thought it was too cool hitting the side of the shed...anyone wanna trade a wife for some spare parts? (hehe just kidding...maybe) but she does buy me more parts so i guess i will keep her...too bad though because it kinda felt like things were starting to click...maybe tomorrow
_____________________________
If it was too easy to learn, it was not worth learning, if it is worth learning, then learning will come easily.
(in reply to ct420)
       Post #: 451
RE: Bdavison's E-flite Blade Assembly - 8/26/2006 2:56:22 AM
ct420
Status: offline
I was sitting in a lawn chair, and had the TX on my lap, but with my hands underneath it. I had it angled down so the antennae was pointing towards the floor. In that position, the IU switch rests gently on my leg.
One day, I was coming in for a landing, and just as the skids touched the floor, I must have moved just right, and my leg pushed the IU switch forward. My BCP did the funky chicken dance for several seconds until I turned the TX off. It was only after this that I realized what had happened
I no longer fly with the TX sitting on my lap... I was planning to mod the TX so I could arm and disarm the IU switch at will, but just haven't ever gotten around to it. Maybe I will do it one of these days...
(in reply to pitch)
       Post #: 452
RE: Bdavison's E-flite Blade Assembly - 8/26/2006 1:13:58 PM
IMAC781
Status: offline
Ct420 know this: It is IMMORAL to fly a heli sitting down. Just a JOKE, son! Maybe you need a TREX to break you out of this complacency
Nothing''s as good or bad as it seems at the time.
(in reply to ct420)
       Post #: 453
RE: Bdavison's E-flite Blade Assembly - 9/1/2006 2:05:57 AM
pitch
Status: offline
i have a question concerning the throttle trim...if i am setting the proportional with the trim all the way up, then when i am flying or hovering should the trim always be put back to full? if it is set this way then running with anything other than full would make it no longer adjusted...would it not. please help me to understand . i love this thread and i am new to helis. just bought a blade pro.
(in reply to bdavison)
       Post #: 454
RE: Bdavison's E-flite Blade Assembly - 9/1/2006 2:59:58 AM
Psikelly
Status: offline
All I do is hover right now and a bit of slow FF and I always run my throttle trim right to the top so that I have a little more left stick travel.
All you can really do is try run it all down and all up and see what the diff is. You cant hurt anything by doing that.
NO I did not just crash!! Im making it flop around on the ground like that on purpose. Its a new stunt.
(in reply to pitch)
       Post #: 455
RE: Bdavison's E-flite Blade Assembly - 9/1/2006 11:42:15 PM
pitch
Status: offline
yeah i seem to be leaning more to the trim all the way up as well. it seems to give you alot more left stick...that way i have more stick to get into trouble with but the hoevring was coming along better until i broke the main frame...now it is a bunch of parts on my kitchen table...thank you school of bdavidson!
(in reply to Psikelly)
       Post #: 456
RE: Bdavison's E-flite Blade Assembly - 9/9/2006 9:16:58 PM
sstamnes
Status: offline
On a different subject, does anyone have any experience with the Precision CNC Rotor Head produced by Microheli? The rotor head looks fantastic and incorporates the Bell Hiller Mixer and the machined swash plate. I found it through Horizon Hobby at: http://www.horizonhobby.com/Products/Default.aspx?ProdId=MHECP002HS3
I hate to upgrade to the E-Flite machined swash plate and Bell Hiller Mixer and then spend more money later on this rotor head.
Shaun Stamnes
(in reply to pitch)
       Post #: 457
RE: Bdavison's E-flite Blade Assembly - 12/2/2006 12:10:30 PM
bluesteel212
Status: offline
ok gota problem i cant fig out i cant get lift on the on the blade cp i check the track it looks good.. fly bar looks level getting a little vibration if i hit ilde up i can get lift ( i am hold blade in had and i can feel it)
but if i take it off i just feel blades spinning and that is it
the 4in 1 i have is the smokey gray one i have motor red wire plug in bottom with red wire in bottom.
Any clues to what i should do?
Tommy
Click to see fullsize image.
Click for fullsize
       Post #: 458
RE: Bdavison's E-flite Blade Assembly - 12/2/2006 4:19:00 PM
pitch
Status: offline
you may have the wires switched. check the rotation of the blades. the main rotor should be going clockwise and the tail rotor should be going counter clockwise.
(in reply to bluesteel212)
       Post #: 459
RE: Bdavison's E-flite Blade Assembly - 12/2/2006 4:40:56 PM
Tall Paul
Status: offline
The motor connections to the CP 4-in-1..
it pays to mark which lead is to which motor.
The channel assignments are for the Spektrum hack.
Click for fullsize
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to pitch)
       Post #: 460
RE: Bdavison's E-flite Blade Assembly - 12/2/2006 5:12:54 PM
bluesteel212
Status: offline
ok the main rotor is going clockwise which side do you look at to check tail?
could it be the way i have the pitch set up i have them level
Tommy
(in reply to Tall Paul)
       Post #: 461
RE: Bdavison's E-flite Blade Assembly - 12/2/2006 7:57:42 PM
drphoto
Status: offline
Tommy, tail rotor blade needs to rotate upward into the downwash of the rotor. (clockwise, when viewed from the rotor side)
       Post #: 462
RE: Bdavison's E-flite Blade Assembly - 12/3/2006 1:12:43 AM
bluesteel212
Status: offline
ok this is my wiring for the motor and from this view the tail rotor is going clockwise but at 50% throttle to 3/4 throttle i am not even feeling wind on my had or pull or push which i should.
so some i am missing or not doing correctly to get this heli to lift off.
Click for fullsize
Click for fullsize
(in reply to drphoto)
       Post #: 463
RE: Bdavison's E-flite Blade Assembly - 12/3/2006 3:14:11 PM
pitch
Status: offline
just looking at the pic on the right the pitch seems to be downward by several degrees. is this a rebuild from a crash? did your heli just start doing this? did you unplug any of the servos from your 4 in 1? if you did you may want to check the sevros as per your manual and check on all the connections. also check your pitch.
