RE: Bdavison's E-flite Blade Assembly
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Bdavison's E-flite Blade Assembly
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Bdavison's E-flite Blade Assembly - 11/2/2005 6:33 PM
hdbint
Score: 100
Last Login: 12/31/2008
Status: offline
quote:
ORIGINAL: AV8TOR
quote:
ORIGINAL: bdavison
Its just for asthetics really. I thought it looked cool and kinda personalized it.
Also the silicone tubing is longer than the rod sticking down on the tail, so if you tail strike it, it gives it a little bounce instead of a hard thwack.
Same for the landing gear. If you cut it to the right length, it's sort of like shocks on the landing struts.
You say it’s sort of like shocks on the landing struts, are you saying that you cut the gear rod and the silicone bridges between the two to act as a shock?
Are the struts glued in?
While I have you Mr. Davison thanks so much for all you are doing and have help with posts on the Blade. I/we really appreciate it.
I could be wrong but I think that Bdavidson is not cutting the struts. He is simply cutting the tubing a little longer than the exposed area of the struts so the tubing is compressed a little bit when installed. This would give it a small amount of bounce.
< Message edited by hdbint -- 11/2/2005 6:35 PM >
Hide Signatures
(in reply to AV8TOR)
       Post #: 101
RE: Bdavison's E-flite Blade Assembly - 11/2/2005 9:49 PM
AV8TOR
Score: 100
Last Login: 7/26/2008
Status: offline
quote:
ORIGINAL: hdbint
Hum ?? I must be confused because you could put a coil spring over a ridged rod and it will still be ridged - no compression - no-bounce.
Hide Signatures
(in reply to hdbint)
       Post #: 102
RE: Bdavison's E-flite Blade Assembly - 11/3/2005 4:06 PM
bdavison
Score: 100
Last Login: 3/11/2010
Status: offline
here's how it works.
Put the gear on like normal. measure the distance between the skid and the lower frame. Now cut four pieces of silicone 1/8" longer. Install them on the helicopter. The gear wont go all the way into the upper frame. What happens now is when you land it compresses the silicone tubing like a shock. Im not sure if it makes much difference though. Ive still broken skids in this configuration, so its mainly just for asthetic looks.
Hide Signatures
       Post #: 103
RE: Bdavison's E-flite Blade Assembly - 11/13/2005 4:49 PM
catfight
Score: 100
Last Login: 10/18/2008
Status: offline
bdavision,
I have read all of your excellent posts about reconstructing a Blade- and found them very handy :0) When do you think you might continue with the next important parts (like head setup and blade adjustments- then advanced? Here's hoping you do. Great stuff.
Hide Signatures
(in reply to bdavison)
       Post #: 104
RE: Bdavison's E-flite Blade Assembly - 11/13/2005 7:30 PM
helidreamer-RCU
Score: 100
Last Login: 5/18/2009
Status: offline
This should be a sticky
_____________________________
Was that the ground?
Hide Signatures
(in reply to catfight)
       Post #: 105
RE: Bdavison's E-flite Blade Assembly - 11/14/2005 4:34 AM
pedester 99
Score: 100
Last Login: 6/6/2009
Status: offline
for sure!
Hide Signatures
(in reply to helidreamer-RCU)
       Post #: 106
RE: Bdavison's E-flite Blade Assembly - 11/14/2005 11:07 AM
helisrgr8
Score: 100
Last Login: 4/17/2007
Status: offline
At what throttle position do you check the blade runout? Is it the same for those of us who spend all their time hovering as it for flying in forward flight?
Hide Signatures
       Post #: 107
RE: Bdavison's E-flite Blade Assembly - 11/17/2005 12:42 AM
crcasey
Score: 100
Last Login: 2/12/2006
Status: offline
I guess my question is when you scale down the blade size for the micro heli's do you need to have a smaller blade pitch gage for it to maintain a level of accuracy?
Is the pitch reading not related to the size of the measurement tool?
I guess I am such a noob that a good reference to using the pitch meter correctly would make these questions make more sense.
Is there a good photo log on how to use a pitch meter?
< Message edited by crcasey -- 11/17/2005 12:48 AM >
____________
Hide Signatures
       Post #: 108
RE: Bdavison's E-flite Blade Assembly - 11/20/2005 9:37 PM
Jhelfire
Score: 100
Last Login: 12/4/2006
Status: offline
Bdavision.
Your assembly session was fantastic. I've been trying to hover my Blade for a week. I went through your adjustments on the Blade and the Pot & Gain controls, took the ship in the garage and was hovering on the third try. Thank you, thank you, thank you. Jhelfire
Hide Signatures
(in reply to crcasey)
       Post #: 109
RE: Bdavison's E-flite Blade Assembly - 11/21/2005 11:47 PM
bdavison
Score: 100
Status: offline
You guys are welcome.
Ive have had a devastating crash with my Blade. Snapped tail boom, sheared the head right in half...literally. Once I can get my hands on replacement parts, Ill finish the thread. I cant finish it with pictures of a busted up blade...
As far as measuring pitch. Get a Align pitch gauge. Its the best one Ive found, and it works great on the micro helis. The gauges for nitro helis are a bit to large and unwieldy to use on the electrics.
Pitch is the same regardless of heli size. 1 degree is 1 degree.
Hide Signatures
(in reply to Jhelfire)
       Post #: 110
RE: Bdavison's E-flite Blade Assembly - 11/27/2005 4:19 PM
glasshole03@yahoo.com
Score: 100
Last Login: 12/4/2007
Status: offline
you've been a great help,thanks.what is wrong with your blade,when the red lite comes on right when you take off?
Hide Signatures
       Post #: 111
RE: Bdavison's E-flite Blade Assembly - 11/27/2005 4:28 PM
Jhelfire
Score: 100
Status: offline
According to Jason at Horizon Hobby, the red light will be on at full power. Turn the throttle off and hold you Blade in your hand. As you increase the throttle at about 3/4 power the red light comes on. This is normal according to Horizon Hobby. Jerry
Hide Signatures
(in reply to glasshole03@yahoo.com)
       Post #: 112
RE: Bdavison's E-flite Blade Assembly - 11/27/2005 4:35 PM
Score: 100
Status: offline
thanks jerry,but when i first got it,it didn't do that till the battery went low. my blade is way out of whack. it is on the table unassembled.
Hide Signatures
       Post #: 113
RE: Bdavison's E-flite Blade Assembly - 11/27/2005 4:42 PM
Score: 100
Status: offline
i guess i have a long way to go before i can fly my blade, but i am dedicated to the cause.this is a very helpful website.
Hide Signatures
       Post #: 114
RE: Bdavison's E-flite Blade Assembly - 11/27/2005 6:05 PM
Score: 100
Status: offline
jerry,i am originally from mundelein il. lake county. have only been doing this ,flying thing for less than a month.i started with a firebird commander 2. then i jumped into the fire with a blade cp. very different.but i really want to learn to fly this thing.i guess it will take some time. i have hovered for a very short time. then i panicked a crashed. now everything is outta whack. just part of it i guess.
Hide Signatures
       Post #: 115
RE: Bdavison's E-flite Blade Assembly - 11/29/2005 2:48 AM
Score: 100
Status: offline
brutal crash,i'll be out for a while. busted the main frame assembly.
Hide Signatures
       Post #: 116
RE: Bdavison's E-flite Blade Assembly - 11/29/2005 5:43 AM
Loswave
Score: 100
Last Login: 2/21/2010
Status: offline
I Crashed my Blade the first day I got it, and destroyed the Main frame. Dissasembled it completely the first day I had it, although I didn't want to. Re-assembled a week later, flys like a champ, and thanks to this thread, I now know for a fact that I did it right! I can't wait until the tracking and tuning thread though, I'm still new to heli's and haven't got all the adjustments down just yet.
Hide Signatures
       Post #: 117
RE: Bdavison's E-flite Blade Assembly - 11/29/2005 6:19 AM
Jhelfire
Score: 100
Status: offline
Horizon Hobby should give away the heli. for what we're paying for parts. I brome my main fram yesterday also. I can't wait for my CX. Should be here this week. I'll let everyone know if it's any easier to fly. Jerry
Hide Signatures
(in reply to Loswave)
       Post #: 118
RE: Bdavison's E-flite Blade Assembly - 11/29/2005 5:11 PM
grosporina
Score: 100
Last Login: 12/19/2009
Status: offline
So am I the only morbid one here who'd like to see photots of the crash damage?
Been flying for a couple of months now without major mishap but I've got this whole thread stashed away on my PC for when I finally have to crack open my new airframe kit and switch over to it.
Great thread dude.
Hide Signatures
       Post #: 119
RE: Bdavison's E-flite Blade Assembly - 11/29/2005 6:07 PM
bdavison
Score: 100
Status: offline
Hmm....crash photos.....good idea....Ill post some tonight!
Ive got some good un's.
Ive got one from my early days with the heli that shows blades splayed out like a blown up cigar, and parts everywhere, the canopy trashed and a tailboom exploded. It happened during a low-level inverted attempted hover.
Hide Signatures
(in reply to grosporina)
       Post #: 120
RE: Bdavison's E-flite Blade Assembly - 11/29/2005 7:28 PM
Jhelfire
Score: 100
Status: offline
Hey Bdavison,
Nice to see you're back. How's the repair comming? Jerry
Hide Signatures
       Post #: 121
RE: Bdavison's E-flite Blade Assembly - 11/30/2005 1:43 AM
catfight
Score: 100
Status: offline
quote:
ORIGINAL: crcasey
crcasey,
Here is a pitch guage and how to use it - this is easy
While measuring pitch, disconnect both motors but power up the TX and RX, then measure with throttle all the way down and then all the way up for your angles.
I found this tool at my local hardware store for $5 (made by General with p/n 29 )- just called "Protractor". It is used to measure inside,outside, and sloped angles. I dissected per the attached photo and now use it to measure my rotor blade angles! You will notice in the 3rd photo- I hold the vertical movable component tighly against the flat side of the blade grip and move it up and down until the bottom of the protractor component is level with the flybar. While holding the vertical against the blade (still) you rotate the bottom of the protractor until it is level with the flybar -and that is it!
The markings on the protractor are centered on 45 degrees - but 45=0 pitch, and 35 = 10 pitch (for non-idle mode). It is really easier than it sounds here.
I was getting frustrated with trying to do the "card stock" pitch guage and didn't feel the desire to purchase a $40 instrument. This works with the Blade CP because the grips are perpendicular to the rotor blades whether symetrical or asymetrical - I don't know about other helis.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by catfight -- 11/30/2005 1:46 AM >
Hide Signatures
       Post #: 122
RE: Bdavison's E-flite Blade Assembly - 11/30/2005 4:54 PM
bdavison
Score: 100
Status: offline
Well,
Im holding off on repairing it until I can get the new bell/hiller head installed. No sense in buying and replacing the entire head, if Im just going to be replacing it with upgrades anyway. Not to mention, Im gonna have to put a section up here about "UPGRADING TO THE BELL/HILLER HEAD"...and I need the head to do it.
Im considering consolidating the last two sections into one. The Performance and Extreme Upgrades section. It will include all sorts of stuff from tail modifications, to rotor head modifications, to upgrading to the bell/hiller head(the best thing since sliced bread). Im not going to do a section on upgrading to brushless motors...and here's the reason.
WASTE OF TIME. If your at the point where you need a brushless motor....your at the point that you need to buy a new helicopter like a Trex or Shogun or MX400 or something. Why waste time doing a hackjob on the Blade when you could just build a new helicopter with less trouble.
Im trying to find that crash pic. Ive got 40 gigabytes of model aviation pics, and sometimes its hard to find just one pic. I need to work on cataloging them or something.
Catfight.....NICE.
< Message edited by bdavison -- 11/30/2005 5:24 PM >
Hide Signatures
       Post #: 123
RE: Bdavison's E-flite Blade Assembly - 11/30/2005 10:42 PM
Score: 100
Status: offline
yes,i think i will do the cx also. and trick out my cp for use after i can fly,getting too costly ,crashin!
Hide Signatures
       Post #: 124
RE: Bdavison's E-flite Blade Assembly - 12/1/2005 1:47 AM
Score: 100
Status: offline
thanks to all ,who contribute!
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.967RCU1
