the Gnome
Joined: 11/24/2006 From: Kamen, GERMANY Status: offline
Hey Bill, I just tried the TP 9 cylinder again on the test stand. To my opinion it don't overheats, I can touch the crankcase and rockerboxes imediately after stopping the engine. It reacts the same, nevertheless if I rev it up 30 seconds or 5 minutes after starting. The following happens: When pulling the throttle from idle, it revs up very nice without hesitation, runs on full rpm (I don't know the rpm yet) for about 5 seconds and then looses power. When the plugs are switched off at full rpm, again 5 seconds after the revs had dropped about 1000rpm, one or two cylinders misfire and die. When I switch the plugs on again at idle, the cylinders get to life again and I can reproduce the process. When I rev it up and leave the plugs heated, it drops the revs even more, but all cylinders keep running. The engine has no response on the needle valve at full rpm, of course, I can make it too lean, but I can' lean it out to best rpm. Without nitro the effect isn't as big as with 10% nitro. Do You think that the ignition timing is too early for the 22 x 8 Menz? Or is the prop too big? I will try a 21 x 6 next time.
