RE: Everything Radial Engines
Tower Hobbies
Logged in as Guest
Users viewing this topic: the Gnome
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Everything Radial Engines
Page: <<   < prev  45 46 47 48 49 50 [51] 52 53 54   next >   >>
Login
RE: Everything Radial Engines - 3/11/2008 8:12:25 PM
the Gnome
Status: online
Hey Woody, sounds as if You were doing right till now, 21x9'' seems to be ok, and 6900 confirms this, You are not lugging the engine. Your venturi size seems to be ok too. I think, as radials suck their mixture through the crankcase, differences in mixture quality can only be felt with big delay and sometimes, small differences, as between correct and a small ammount rich, can't be felt at all. This makes adjusting a radial a bit difficult, even on my ST710 Seidel I can only tell the right main needle setting by testing the upper mid range load / revs, at full throttle it's very difficult to feel a rich mixture and absolutely impossible to find the correct needle setting.
You seem to be advanced radial user enough to set the carb right, so I'm affraid there is no other advice than to test plugs of different heat, on my Seidel ST540 colder plugs cured some similar problems. The most signifficant effect was, that, when pushing the stick to full throttle, revs got to about 6500 and after about a second dropped some 500 to 800rpm. If You can find a similar effect on Your 400, may be a too much advanced ignition timing is the basic problem. When the engine gets warm or hot while flying, this may cause even worse engine behavior.
What do You think?
gnome
Holm und Rippenbruch
(in reply to woody260)
       Post #: 1251
RE: Ev... - 3/13/2008 5:41:09 PM
dharrell
Status: offline
Need some advice on spinners.............I have an aeorworks stearman with OS 5300 radial. Any advice on what to get?? Thanks
Dean
       Post #: 1252
RE: Everything Radial Engines - 3/23/2008 12:05:43 AM
dharrell
Status: offline
I just bought an OS 5300 and have a stupid question....................I cannot get the glow plug out with my usual wrenches, the ones I have do not seem to "seat" far enough down to unscrew it, I think. I have tried two or three others that don't seem to work..............anyone else have this problem?? Thanks
Dean
(in reply to William Robison)
       Post #: 1253
RE: Everything Radial Engines - 3/23/2008 12:34:44 AM
SJN
Status: offline
Woody:
Is your fuel tank pressurized ?
Dean, on a few of my ASP 4 strokes, I have to use a very thin walled X wrench to get to the plug......
< Message edited by SJN -- 3/23/2008 12:35:05 AM >
_____________________________
Sonnich Johannesen
(in reply to dharrell)
       Post #: 1254
RE: Everything Radial Engines - 3/23/2008 1:33:15 AM
dharrell
Status: offline
That is good to know. Where can I get one of these?
(in reply to SJN)
       Post #: 1255
RE: Everything Radial Engines - 3/23/2008 2:23:18 AM
SJN
Status: offline
Got mine with an RC car kit long time ago
Sonnich Johannesen
       Post #: 1256
RE: Everything Radial Engines - 3/23/2008 3:03:18 AM
Clutch Cargo
Status: offline
Dean,
A metric socket will work also
Zagi_x
(in reply to SJN)
       Post #: 1257
RE: Everything Radial Engines - 3/23/2008 3:10:29 AM
Dad_Roman
Status: offline
In the way-way-back machine, wrenches used to come with motors, my experience was mainly the Saito line. This wrench was a thin machined, tubular shaped glowplug socket about 3 inches long (maybe 2" ) and have a hole in the top to run your favorite allen wrench through for a handle. These were specifically designed to slip into the tight space on the engine fins etc. to remove the glow plug. This was especially true on my 30 and 40 open rocker engines. If you can find one or some one who has one it will help you tremendously.
Still searching for a 3-5 cu. in. radial for sale (hint,hint,hint)
< Message edited by Dad_Roman -- 3/23/2008 3:16:04 AM >
AMA# 134406
(in reply to SJN)
       Post #: 1258
RE: Everything Radial Engines - 3/23/2008 5:46:00 AM
Kmot
Status: offline
Just get any old 1/4" nut driver, and grind the walls thin till it fits.
Ahhh......screw it!
(in reply to Dad_Roman)
       Post #: 1259
RE: Everything Radial Engines - 3/23/2008 9:31:45 AM
dharrell
Status: offline
MANY THANKS FOR THE SUGGESTIONS.
DEAN
(in reply to Kmot)
       Post #: 1260
RE: Everything Radial Engines - 3/23/2008 5:46:43 PM
Aluminum Overcast
Status: offline
You can also use a piece of silicone fuel tube (with the smallest inner diameter) to help start the plug onto the cylinder head. Do this by pushing the electrode of the plug onto the tubing. Then, begin to thread the plug onto the cylinder using the tubing as an extension. Once you have a few revolutions on the plug just pull the tubing off the plug and finish tightening with the wrench. This is a great way ensure the threads of the plug are meshing correctly with the threads from the cylinder and will ensure against any cross threading.
       Post #: 1261
RE: Everything Radial Engines - 3/23/2008 8:11:04 PM
nilsreinert123
Status: offline
I have a question regarding my ASP 400 ; is it normal for a 5 cylinder glow radial to not run properly when the glow ign. is removed ,even at mid revs. My Saito 90 r3 ran fine without glow driver ,but my ASP need it all the time . Do the saito 325 and os 300 need the glow drivers almost all the time too?
(in reply to Aluminum Overcast)
       Post #: 1262
RE: Everything Radial Engines - 3/23/2008 9:26:28 PM
Ram-bro
Status: offline
explain "not runs properly?"
(in reply to nilsreinert123)
       Post #: 1263
RE: Everything Radial Engines - 3/23/2008 10:01:53 PM
nilsreinert123
Status: offline
When i disconnect the glow battery the engine does not run clean , it does not fire on all cylinders.
(in reply to Ram-bro)
       Post #: 1264
RE: Everything Radial Engines - 3/23/2008 10:23:18 PM
Kmot
Status: offline
Try a set of fresh new glow plugs and see if it still does it.
Ahhh......screw it!
       Post #: 1265
RE: Everything Radial Engines - 3/23/2008 10:37:22 PM
Aluminum Overcast
