RE: Everything Radial Engines
Tower Hobbies
Logged in as Guest
Users viewing this topic: Aerobatt
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Everything Radial Engines
Page: <<   < prev  45 46 47 48 49 50 51 [52] 53 54   next >   >>
Login
RE: Everything Radial Engines - 4/1/2008 2:48:24 PM
wagrubbs
Status: offline
Hi,
I am a partner in a venture capital firm and we would like to display some classic examples of outstanding engineering in our office. Do 18 cylinder scale models ever come up for sale? Or, can they be commissioned? Or other exotic engine models (V-12's, Offy's, etc.) I understand that I am talking about serious money here, and that these are works of art.
I will be at the NAMES exposition on April 19, in case anyone wants to get together there.
Thanks very much,
Andy Grubbs
Chapel Hill, NC
(in reply to Kmot)
       Post #: 1276
RE: Everything Radial Engines - 4/1/2008 4:11:17 PM
stevesak
Status: offline
Andy,
To my knowledge, there is nothing offered in an 18 cylinder double row radial engine.
The closest that you may find is the 500cc Seidel ST-14-500. It is a double row 14 cylinder Seidel engine and I believe that it is currently available overseas for $6000 euro, or about $9,250 USD. You might try top-collect.de for more information.
Here is the link. http://top-collect.de/cms.asp?NoReset=1&Produktseite=2&H=5912&Produktkategorie=5912
The only 18 cylinder that I can think of, would be the Hodgson 18, but they are about as common as hens teeth. Any that might be in existance would have been created by the home shop machinist, so if indeed you ever would find one, then it may not have the polish and refinement that you are looking for. www.ageless-engines.com
I hope that this helps,
--->Steve
... Also, you will likely find an interesting multicylinder engine on ebay every 2-4 weeks. Replica Engines made a 1/4 scale offy. Also a Knuclehead, Curtis and various others. Again.... they are sold out might come up on eBay a couple times per year. (Ususlly for about 5K).
Commissioning someone to do the work is not practical, as folks might spend upward of 2,500-4,000 hours building one of these engines. Most end up as family heirlooms but again, they do pop up from time to time.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by stevesak -- 4/1/2008 4:19:28 PM >
(in reply to wagrubbs)
       Post #: 1277
RE: Everything Radial Engines - 4/1/2008 6:25:26 PM
wagrubbs
Status: offline
Thanks very much for the information!
I probably need to take out a few ads to let folks know I am in the market for these items. I am sure that somewhere out there is a master machinist with a fabulous model who dreads giving it to unappreciative children or grandchildren and could use the cash. It may take a while, but I will keep looking!
Andy
(in reply to stevesak)
       Post #: 1278
RE: Everything Radial Engines - 4/3/2008 9:08:01 PM
dharrell
Status: offline
I have an OS 5300 sitting on an Aeroworks Stearman. Any recommendations for a spinner or prop hub for the engine?
Dean
(in reply to William Robison)
       Post #: 1279
RE: Everything Radial Engines - 4/3/2008 9:18:20 PM
Broken Wings
Status: offline
quote:
ORIGINAL: dharrell
Dean
These guys make some very nice stuff
http://www.soloprops.com/
_____________________________
Regards,
John
(in reply to dharrell)
       Post #: 1280
RE: Everything Radial Engines - 4/3/2008 10:17:57 PM
Aluminum Overcast
Status: offline
I second that regarding Solo Props. I have a 4 bade on my Spitfire from them and it is awesome workmanship and scale realism.
Click for fullsize
(in reply to Broken Wings)
       Post #: 1281
RE: Everything Radial Engines - 4/3/2008 10:28:05 PM
dharrell
Status: offline
Thanks for the advice
(in reply to Aluminum Overcast)
       Post #: 1282
RE: Everything Radial Engines - 4/4/2008 12:20:03 AM
Dad_Roman
Status: online
quote:
ORIGINAL: Aluminum Overcast
Hey AO, does that 4 blade prop pull well? It looks like the scale blades. If it is, try to get us an overall view. Thanks
AMA# 134406
       Post #: 1283
RE: Everything Radial Engines - 4/4/2008 2:27:43 AM
Aluminum Overcast
Status: offline
This model is still in the works so the prop has not flown. It has been run on the RCV engine and seems to pull quite well......Being able to dial in more pitch is great for using all the power the engine can make. I did make sure the engine is below it's recommended max rpm to account for it unloading in flight so I'm about 5,600. Max for this engine at the prop is 6,000.
The prop blades are wood and are pre balanced and painted by carl at Solo Props. The profile for the blades are for the Spitfire, he can cut any profile upon your request. Nice guy to deal with.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Dad_Roman)
       Post #: 1284
RE: Everything Radial Engines - 4/4/2008 2:57:35 AM
Dad_Roman
Status: online
Thanks for that...very VERY nice!
AMA# 134406
       Post #: 1285
RE: Everything Radial Engines - 4/4/2008 5:11:16 AM
kochj
Status: offline
I have a solo prop from Carl as well.....
Awsome guy to deal with......
He will go the distance to make you happy!....
Also....
Is it true that ASP/Magnum NO longer is manf. the 5cy radial???
Justin
Winning isn''t everything, it''s all there is.
       Post #: 1286
RE: Everything Radial Engines - 4/4/2008 5:12:45 AM
Kmot
Status: offline
Where did you hear that from? Oh, and the engines are manufactured by Sanye, the same company that makes RCV.
< Message edited by Kmot -- 4/4/2008 5:13:54 AM >
Ahhh......screw it!
(in reply to kochj)
       Post #: 1287
RE: Everything Radial Engines - 4/4/2008 2:03:53 PM
stevesak
Status: offline
KMOT, Isn't RCV made in the UK? Or are they a UK company who outsourced their manufacturing to China? I thought that Sanye makes the Magnum, ASP and SC engines. Are there others too?
I just checked the Sanye website and it looks like the FS400AR is still listed. Of course, I don't think that they have updated their website in 3 years and the english site was never completed. Navigating the Chinese pages are pretty rough.
I'll list the website for reference, but I don't think that it will do anybody much good.... http://www.sanyemodel.com/
I once had my wife look at the website for me, but things like 2 vs. 4 cycle, bore, stroke, etc. don't mean much to her so I didn't get much feedback from her. (It's kind of like transating a law book).
(in reply to Kmot)
       Post #: 1288
