RE: Everything Radial Engines
Tower Hobbies
Logged in as Guest
  Printable Version
K&B .40 R/C Ball Bearing
Seller:  area51jmitch
Details:   $75.00   |  8/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Everything Radial Engines
Page: <<   < prev  46 47 48 49 50 51 52 53 [54] 55   next >   >>
Login
RE: Everything Radial Engines - 6/7/2008 1:50:52 AM
Cybertom
Status: offline
I think that cost is a BIG factor when you consider that you can buy a Saito 5-cylinder radial for around $1,400 and the R780 is $4,000. Of course the R780 is a 7-cylinder, and is incredibly scale compared to the Saito. It also has over twice the power. Still I think most people can't justify burnging 4K on a radial.
_____________________________
Real airplanes have 2-wings and round engines!
(in reply to baron-noir)
       Post #: 1326
RE: Everything Radial Engines - 6/12/2008 10:50:19 PM
MarvinE255
Status: offline
I have a Seidel ST 770 that I would like to use in a Bucker Jungmeister. I am looking for a Rodelmodell 78" wing span kit. Does anyone know where it can be purchased. Euroscaleusa used to advertise them in the US but I don't think they are still in business. Any web site I can order it from would great. Thanks
DOC
(in reply to Cybertom)
       Post #: 1327
RE: Everything Radial Engines - 6/24/2008 4:33:26 AM
stuntgoat95
Status: offline
Buiding a Don Smith FW190 1/4.5 scale 89" wing spang. I'm guessing the final weight will be about 30-40 lbs. Want to put a radia in it.
Looking at the 3W engines, but not much has been said about them.
Any recommenations?
SG
(in reply to MarvinE255)
       Post #: 1328
RE: Everything Radial Engines - 6/24/2008 4:38:45 AM
stuntgoat95
Status: offline
Buiding a Don Smith FW190 1/4.5 scale 89" wing spang. I'm guessing the final weight will be about 30-40 lbs. Want to put a radial in it.
Any recommenations?
SG
(in reply to stuntgoat95)
       Post #: 1329
RE: Everything Radial Engines - 6/24/2008 6:57:33 AM
baron-noir
Status: offline
Re : Roëdel order you can see their website : http://www.roedelmodell.de/frames/frame1.html Be aware that you can order the kit already structurally finished (ARC) altough this might not be an option for you transportation wise. I choose this option for their M109 and the build quality was top notch. I was considering the Bucker also for a Seidel engine but I had to refrain from it, as I didn't like the front glass parts.
Sk
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by baron-noir -- 6/24/2008 7:02:38 AM >
Back by Dope Demand - The King Bees
       Post #: 1330
RE: Everything Radial Engines - 6/24/2008 9:24:32 PM
MarvinE255
Status: offline
Thanks for the information.
DOC
       Post #: 1331
RE: Everything Radial Engines - 6/25/2008 2:07:16 PM
Senfschneider55
Status: offline
Hi Guys
Check this out!!
Seidel gas radials !!! http://www.seidel-triebwerke.de/seidel-triebwerke-home.htm
It´s in German but easy enough to understand.
look at the ST 7-160 B ( the B is for benzin/gas )
Available in the fall, but pricey!!
Irv
The German word for bra = STOPSEMFROMFLOPPIN
In God we trust. All others must pay cash
       Post #: 1332
RE: Everything Radial Engines - 7/8/2008 8:37:07 PM
nilsreinert123
Status: online
The 14/500 is unbelivable!! who is flying a plane with that engine??
And are there a video of it running somewhere?
< Message edited by nilsreinert123 -- 7/8/2008 9:18:46 PM >
(in reply to Senfschneider55)
       Post #: 1333
RE: Everything Radial Engines - 7/12/2008 8:01:46 PM
Aluminum Overcast
Status: offline
Hey guys.....Has anyone taken out their low speed needle on their ASP 400R and looked at the o ring there? Mine seems to be pinched but I just wan to confirm that this is not normal. My engine will run on prime from the exhaust stacks but will not from the carb......I suspect this is o ring is the problem. Any suggestions on needle valve setup for the high and low speed.....my low speed was way unscrewed out of the box!
Click for fullsize
Click for fullsize
< Message edited by Aluminum Overcast -- 7/12/2008 8:06:25 PM >
       Post #: 1334
RE: Everything Radial Engines - 7/12/2008 9:02:04 PM
Cybertom
Status: offline
nilsreinert123,
It would be tough to find an appropriate airplane for that engine because of its weight. Most of these radials are going biplanes because they have enough wing area to support the weight. I can't see this being in a big Corsair or Thunderbolt without the airplane being so large that the engine would be totally under scale in appearance. Try to fit it in any fighter that is near scale for the engine and it would be extremely nose heavy.
I am amazed with the FW190 by Air World running the RCS 215. That combo seems to work but I'm thinking there won't be a long nose D version because the engine weight way out on that long nose would make it difficult to balance.
(in reply to nilsreinert123)
       Post #: 1335
RE: Everything Radial Engines - 7/12/2008 9:19:02 PM
SJN
Status: offline
the composite ARF corsair is also nice for the moki 215 or 250 :-)
http://www.youtube.com/watch?v=_T9_7EfwnkA
Sonnich Johannesen
       Post #: 1336
RE: Everything Radial Engines - 7/12/2008 9:34:47 PM
Kmot
Status: offline
AO: That is definitely not normal. The o-ring needs to be replaced.
Ahhh......screw it!
(in reply to SJN)
       Post #: 1337
RE: Everything Radial Engines - 7/12/2008 10:07:42 PM
Aluminum Overcast
Status: offline
Thanks Kmot........ I figured as such but just wanted confirmation. I'm sure that has been my problem in getting her going all along. I'll look into the o ring replacement. I would think a few engines uses a very similar size. Anyone know which for sure? I would think the OS would be similar.
(in reply to Kmot)
       Post #: 1338
RE: Everything Radial Engines - 7/12/2008 11:50:22 PM
Cybertom
Status: offline
SJN,
I stand corrected. However, you have to admit that it looks as though they dramatically increased the wing area and went with a high lift airfoil. All in all I'd have to say they did a great jo
