Cybertom
OH, USA Status: offline
Chasrb, I'm going to use the supplied tube to join last two formers which will give the fuselage torque strength. I will put a 1/8" sheet of plywood to cover the face of the firewall just like I did on my first Stearman. The "change" will be that I am going to weld my own chrome molly steel tubing semi-scale motor mount. It will look very similar to the way the Robart R780 motor mount is constructed but have the thrust angles and correct length built in. I plan to attach it directly to the firewall. I have done some welding and brazing in the past so decided to buy some really nice precision welding equipment tailored to creating miniature components. I also purchased some videos on aircraft frame and chrome molly welding. It should be very scale, strong, functional, and light.
_____________________________
Real airplanes have 2-wings and round engines!
