Nitronutt
OH, USA Status: offline
Everything recently published seems to lean toward running (At break-in) the same fuel that you will be using after break-in. My SH manual said to use 20% Nitro or lower during break-in, and I did. On my Mach, I broke it in on Trinity 30% Nitro, 12% Oil (and run the 1st 2 gallons) and it has been MUCH easier to tune, been extremely consistent day to day and has required no more that 1/8 turn (HSN and/or LSN) adjustment either way for optimal running over the last month!!! I think it is more important to do the heat cycling than to run the exact same fuel...although doing both can't hurt. On your break-in, I would run at least 15% Nitro - All big blocks are designed for 20% (even 30% is usually fine without needing to add a shim to the head). After break-in, I wouldn't run anything less than 20%. On the oil...I can't recommend a percentage because all oils are different and many fuel manufacturers use synthetics along with Racing castors...and I am not a fuel manufacturer. In a commercially available (Brand Name) fuel, I recommend 14% or less oil for better and cooler running.
_____________________________
LST-Mach-23mm-Big Joes-RPM • Jato-Dirt Hawgs • RC10T Wide Stampede-FLM Ext. Chassis-Mamba 5700-11.1v Lipo-Lockd Dif
