3d electric arf's
Tower Hobbies
Logged in as Guest
  Printable Version
Calmato Sports EP 1400 Trainer W/Motor - ARF
Seller:  highres4
Details:   $99.00   |  12/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> 3d electric arf's
Page: [1]
Login
3d electric arf's - 7/9/2005 4:06:09 PM
pro2k
Status: offline
Are there any nice 3d arf's that are capable of hovering out there? I'm looking for something nice that is more than just flat pieces of foam stuck together. I don't know where to look as I am just coming over from heli's!! Thanks!
       Post #: 1
RE: 3d electric arf's - 7/9/2005 4:32:05 PM
3DHobbyShop
Status: offline
If you're just starting fixed-wing aerobatics, you might want an EPP plane, bouncy and hard to break. We have the R3DMini which is a small-sized full-fuse EPP plane. HobbyLobby has a full-fuse EPP plane, and GP calls theirs a UCanDo 3DEP. So, yeah, there are some choices for first 3D planes that aren't flat. Also, hovering is getting pretty effortless with the newer brushed motors, and more and more people are flying EPP planes with almost 2:1 thrust to weight ratios.
(in reply to pro2k)
       Post #: 2
RE: 3d electric arf's - 7/9/2005 4:34:59 PM
emnm79
Status: offline
well, the EF yak is more than flat peices of foam stuck together, its a whole bunch stuck together to make an a frame fuse, but still has a flat wing, it is a very very good plane... the R3D series have airfoils and are made of EPP flight flex foam, I've seen one crash about 50 times in one day, and it still flies without any problems or repairs, just put the prop/oring back on, and throw it in the air... the mini is relatively easy to fly indoors, the larger is probably harder, but i'm thinking its definitely possible... you can find the yak at www.horizonhobby.com , and the r3d's at www.3dhobbyshop.com
(in reply to pro2k)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU2
