tail boom on blade
Tower Hobbies
Logged in as Guest
  Printable Version
Dragonus II Pro RC Helicopter - RTF
Seller:  appy2323
Details:   $475.00   |  11/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> tail boom on blade
Page: [1]
Login
tail boom on blade - 7/15/2005 1:03:05 AM
ads8525
Status: offline
is the tail boom slightly glued to the main frame of the blade heli so it does not twist? My tail hit the ground slightly and now the boom twists, I can only assume horizon slightly glued it becuse I can find no other way to attach it without it twisting.
       Post #: 1
RE: tail boom on blade - 7/15/2005 1:14:52 AM
newbhelichopper
Status: offline
I just encountered the same problem yesterday. I haven't yet bothered to glue it or anything. I would say so they did glue it on the inside a little bit. I might as well go do that.
Matt
< Message edited by newbhelichopper -- 7/15/2005 1:15:15 AM >
(in reply to ads8525)
       Post #: 2
RE: tail boom on blade - 7/15/2005 2:12:00 AM
ads8525
Status: offline
are you new to helicopters? just wondering becuase this is my first...just curious of how someone new like me is progressing with their Blade.
       Post #: 3
RE: tail boom on blade - 7/15/2005 3:12:56 AM
newbhelichopper
Status: offline
quote:
ORIGINAL: ads8525
Actually yes, I'm new to this hobby. Although I don't have a Blade, I have Walkera Dragonfly 4, which is a good helicopter after minor modifications. Basically the tail rotor system on the Blade is the same as my helicopter.
Matt
       Post #: 4
RE: tail boom on blade - 7/15/2005 3:28:07 AM
ads8525
Status: offline
how did you learn to make all the adjustments to get yours to hover more stable? I have tried and tried but mine whole heli keeps pulling to the left...a guy told me it could be the ailerons need adjustment but I tried that with no help...any suggestions?
       Post #: 5
RE: tail boom on blade - 7/15/2005 7:47:12 AM
acr1346
Status: offline
CA (small drop) the tail. Have some debonder for when the boom breakes so you can remove it.
The almost always drift while attempting to get off the ground. If it still drifts at about one to one and an half
feet off the ground and the right/left trim has not affect, you have an adjustment problem in leveling the
swash plate in line with the heli frame, fore and aft and side to side. moving the trim should tilt the swash
from level. FYI the heli does not hang in the air straight up and down like a plumb bob. It hangs at a slight
angle (the reason for the drift just priot to lift off).
_____________________________
You can fly the Empire State Building if the motor is big enough!
       Post #: 6
RE: tail boom on blade - 7/15/2005 4:12:58 PM
ads8525
Status: offline
Thanks for the info
(in reply to acr1346)
       Post #: 7
RE: tail boom on blade - 7/16/2005 2:08:40 AM
bdavison
Status: offline
One other thing worth mentioning, is that when you reattach the tail boom. Make absolutly sure that the tail rotor is perfectly lined up vertical. If its tilted or canted, it will make the heli almost un-flyable.
teamflyingcircus.com
       Post #: 8
RE: tail boom on blade - 7/16/2005 2:12:59 AM
newbhelichopper
Status: offline
quote:
ORIGINAL: ads8525
I balanced the blades so that both of them weigh the same, and balanced the fly bars, so both sides are even as well. Also I should mentioned that my flybar is 1 inch shorter than stock because it broke off, so I evened the edge with sand paper, and fitted it back on so that each sides are even.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU2
