lsnover
Joined: 4/29/2002 From: Bath, PA, USA Status: offline
quote:
ORIGINAL: hpergm I just got delivery of the plane yesterday and I'm going over it. Construction looks very nice and it should prove a really sturdy airframe. Upon first inspection I can see a few areas where weight can be shaved off. I will be posting some comments about weight savings later on. I have also made a list of the weight of various components, for those who are interested (all figures in grams): Rudder: 120 Fin&Post: 47 Right Stab +Elevator: 120 Left Stab +Elevator: 118 Carbon Stab Tube: 13 Aluminium Stab Rod: 12 Cowl Uncut: 330 Canopy Semi-Uncut: 144 Hatch w/o Floor: 148 Hatch Floor: 58 Left Wing Panel w/Aileron: 711 Right Wing Panel w/Aileron: 723 Wing Tube: 159 LG Legs: 231 Bolts for LG: 10 Fuzelage: 1590 Wheel Pants+Bolts: 65 Tank Floor: 15 Tail Wheel Assy: 55 Axles: 55 Various Bolts (Wings, etc): 70 Horns +Bolts: 34 Total: 4828 or 10.63lbs. Projected AUW with my setup (I have weighed all components: DA50, can/header, hitecs, Li-Ions, Regulator, Spinner etc.) is at the moment 17.8lbs. Out of academic interest, I also measured the wing span and area, the latter by measuring all major dimensions, drawing the planform in Autocad and using the "Area" tool. What I found is interesting.... The span of the plane assembled is ~82.9" (2105mm), not 84". You will only get 84" if you pull the wings out of the fuz sockets and leave them just touching the exterior skin)... The area of the two main wing panels (root chord 530mm, tip chord 270mm and semi-span 945mm) off the fuz is 1164 sq.in (only?!). If one adds the central fuz area of ~202sq.in. (project wings into fuz until "joined" and subtracts the area of the wing fuz sockets (~36sq.in.) then the wing area is not 1410sq.in. but 1330sq.in.! Could someone verify my measurements? If true, the model seems off both in weight and wing area specs...! A quick calculation of the wing loading with the "true" figures reveals that 17.8lbs/1330sq.in. = 284.8oz/9.236111sq.ft. = 30.83oz/sq.ft!. Unfortunately, none of the ARF manufactuers seem to be too accurate when giving their initial specifications, and they always tend to lean towards the optimistic side. A few of us have mentioned that we are a bit disappointed in this planes overall weight. However, it does seem in line for other planes of this general size. We can all hope for lighter, but beings that the Asian assemblers are all picking out of the same general stocks of raw materials, that is probably unrealistic, unless we are willing to pay "more" for models of a "premium" variety where these folks will take the time to cherry pick the best stocks of balsa and ply, and other components. I do wish ALL the companies would have a ittle more "truth-in-advertising" regaring their weights and dimensions. So many of them are stretching the truth (on purpose maybe) that it's probably be hard for the competition not to play the same game. Regards, Lee Snover
