lsnover
Joined: 4/29/2002 From: Bath, PA, USA Status: offline
quote:
ORIGINAL: Aerotech Hello, Yes it will work. You may have to put some exhaust extentions on the muffler, but thats simple with some aerotrend tubing and some zip ties. Let me know if I can help further. Thanks John www.aerotech-rcmodels.com John: Thanks for the info. This looks very similar to the TOC YAK, with reports coming out in the higher end (around 18lbs) of the weight scale. Is this the same model? I'm concerned the finished weight will be much more then advertised. Your engine mount looks somewhat different, but overall there seem to be many simularities. If using the DA50, are standoffs required? I sent you folks an email with some more detailed questions, and would appreciate hearing back on those. Thanks! Lee Snover
